@05-15 Tacoma Antenna/Led Pod/Camera Mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaliRaisedLed, Feb 5, 2018.
  1. Feb 5, 2018 at 10:50 AM
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    This Mount allows you to do a variety of things. Mount a Rear facing LED Pod, CB Antenna, GoPro Camera, or anything else you can imagine. Made from 12 Gauge cold rolled steel CNC Cut and welded for added strength. Bracket comes powder coated with a texture black finish. Bracket install takes roughly 2 minutes. Direct bolt on with no cutting or drilling. FREE SHIPPING
    https://www.youtube.com/watch?v=tmwl8R5jGco
    Check out our installation video!
  2. Feb 5, 2018 at 10:54 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Pretty cool how will it work with people who have bought the bed stiffeners???
  3. Feb 5, 2018 at 10:56 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Depends which vendor the bed stiffeners came from.
    Some extend up to that bolt location, others dont.
    outxider and Unchained 5150 like this.
  4. Feb 5, 2018 at 10:57 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I have a similar brand to this one on the driverside with the bed stiffeners - I think I just put the antenna mount on the bolt side of the stiffener and bent the bracket at more of an angle to fit.. It scrapes a bit but works fine.
  5. Feb 5, 2018 at 11:00 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Exactly, there are some bed stiffeners that mount in other locations than others. But also we will be making a new product line of bed stiffeners that will work perfectly with our Mount.
  6. Feb 5, 2018 at 11:03 AM
    Bruce988jl
    Southern NH
    Or... make bed stiffeners with built-in mounts? :D
  7. Feb 5, 2018 at 11:06 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I would also be weary if you already have the steel tailgate skins and caps. I know my cap from VooDoo just barely makes contact with the bolt used in that location and it's also a hair wider than the tailgate itself.
    ChadsPride likes this.
  8. Feb 5, 2018 at 11:08 AM
    Bruce988jl
    Southern NH
    I have the voo-doo as well - all I did was loosen then skin and shifted it away and no issues.
    I might buy one of these to have a mount on both sides...One for the CB the other for a led or something.
  9. Feb 5, 2018 at 11:10 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Also if you have the Voo Doo bed caps the metal is thicker where the bolts go in as well.
    Chase8059 and ChadsPride like this.
  10. Feb 5, 2018 at 11:11 AM
    Chase8059
    Chase
    ESVA
    Yea, there have only been a few of us who can't get his cap to fit without touching that bolt. I ended up just taking it off while I looked for a more flushed bolt head to use. That was about 10 months ago and I still haven't put the bolt back on. :anonymous:
  11. Feb 5, 2018 at 11:11 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Yes, Some companies to mount there bed stiffeneres to those two bolts where our mount mounts too. But that we know of most companies don't go that high on there mounting loaction. But very soon we will be offering that as a new product.
  12. Feb 9, 2018 at 1:20 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    https://youtu.be/rkYWhPMSyJA
    here’s a cool little vid we made at the shop yesterday showing off our sheet metal line! We have tons of new stuff coming out so stay tuned!
    Climberclimb and ChadsPride like this.
  13. Feb 22, 2018 at 6:32 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
  14. Mar 1, 2018 at 4:04 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    REDdawn6 likes this.
  15. Mar 1, 2018 at 6:55 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I don't need one of the brackets but man, that brake is sweet! I'd bend up all sorts of stuff I had no use for just to play with it. :bananadance:
    CaliRaisedLed[OP] and Hawco636 like this.
  16. Mar 1, 2018 at 8:42 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    It’s a very fun machine to use :thumbsup:
  17. Mar 9, 2018 at 4:26 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Also one thing to consider is the hole position for mounting things on this. I had to make another hole farther towards outside of truck on mine because my leer 100R shell rear window wouldnt close with my led pod mounted there. Just something to consider if you have a shell and get this ask them to put the hole wider to accommodate. Or re drill yourself.
    LocoLocal likes this.
  18. Mar 9, 2018 at 8:34 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Perfect we appreciate that feed back for future customers!
  19. Mar 29, 2018 at 12:46 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
  20. Apr 2, 2018 at 1:17 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
