05-15, TRD Sport and Off Road Suspension Characteristics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glk21c, Oct 30, 2017.
  1. Oct 30, 2017 at 7:26 AM
    glk21c
    glk21c [OP] Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    If you know there is a/are thread(s) about this already, please provide the link(s).
    I know the sport suspension is stiffer where the off-road suspension is a little cushier. I distinctly remember, way back on 2007 when test driving the Tacoma's that I could definitely feel the difference between the two.
    My question is this, does anyone know for sure is the difference in the ride strictly done through different valving in the Bilstein shocks that are used or no, it's the shocks and the, at least in the front, the coil springs as well.
    Just considering at me next shock absorber change maybe going with the off-road shocks instead of the sports I always used.
    Oh, I have no interest in going aftermarket.
    Thanks in advance
  2. Oct 30, 2017 at 7:32 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    As far as I know the OR uses progressive springs up front. Same shocks as the sport.
    The sport has a thicker sway bar I believe.
    You do realize the stock billy's are basically aftermarket, right? And they're complete garbage IMO. Once you swap them out the ride improves dramatically.
  3. Oct 30, 2017 at 7:37 AM
    DANGERMONEY
    DANGERMONEY Well-Known Member
    I'm interested in knowing as well.
    I have the off road but would like to tune the suspension for more highway use.
  4. Oct 30, 2017 at 7:42 AM
    Taco Tacoma
    Taco Tacoma Well-Known Member
    Dylan
    Napa CA
    '21 Cement SR5 4x4 DCLB
    '21 Nothing so far, I just bought the friggin thing!! '09 Silver SR5 Prerunner DCSB (sold) Dick Cepek rims, 33” Cooper AT 3’s, 24 in light bar, custom-made hitch step, sport headlights (on SR5 taco), Gator tonneau cover (looking for Best Top soft camper shell), real tree seat covers, weather tech floor liners, 6’ bed mat cut to 5’ (because the 6’ ones were the only ones available, alpine touch screen head unit, alpine 1100w amp powering 2 10” subs, upgraded door speakers (forgotten the brand), Magnaflow exhaust
    I understand keeping stock suspension but most of the stock configurations are very much the same, only small differences between them. For instance my SR5 factory has the same ride as the Sport, since the sport package is mostly a cosmetics pacage (hood, color match bumpers, mirrors depaonfing on year, wheels, etc.) so if you want soft you really need to go aftermarket.
  5. Oct 30, 2017 at 7:46 AM
    Pigpen
    Dan
    Northwest Montana
    It's the coil springs on the front. As mentioned above, the OR uses progressive rate coil springs to absorb small bumps more smoothly and make driving off road a slightly smoother experience. All other models have the same linear rate coils. I'm pretty sure all second gen Tacos have the same sway bar. I'm also pretty sure the TRD OR and Sport have the same shocks also.
    Taco Tacoma likes this.
  6. Oct 30, 2017 at 7:51 AM
    Taco Tacoma
    Dylan
    Napa CA
    I’m not an expert nor have I spent a lot of time studying Tacoma suspensions but I can see that the OR and sport trucks would have the same shock, but to my highly trained ass it felt the same as other tacos I’ve ridden/driven.
  7. Oct 30, 2017 at 7:55 AM
    Pigpen
    Dan
    Northwest Montana
    My base model V6 had the same springs as the Sport, but different shocks. They all had the same shitty rear leaf springs - some randomly got the 3 leaf pack. others randomly got the 4 leaf pack.. Both suck.
  8. Oct 30, 2017 at 7:58 AM
    Taco Tacoma
    Dylan
    Napa CA
    I think the ones with 4 leaf packs have the towing pacage like my truck and 3 leaf packs are just your regular non tow package ones, hints why you can two double with the two package over base.
  9. Oct 30, 2017 at 8:01 AM
    Pigpen
    Dan
    Northwest Montana
    Nearly doubling the tow load has more to do with the class 4 hitch and trailer brakes (and transmission cooler on auto trans models) than leaf springs. not arguing, just adding more info
    Edit: though you may be absolutely right about stock tow package trucks having the 4 leaf pack. I've never even heard this theory presented. It makes good sense. Put up a poll!
  10. Oct 30, 2017 at 8:03 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    3 leafs were for the OR even with the tow package.
  11. Oct 30, 2017 at 8:05 AM
    Pigpen
    Dan
    Northwest Montana
    So it was pretty much random then :pout:
  12. Oct 30, 2017 at 8:08 AM
    jpereira2
    Massachusetts
    I believe every 4wd got 4 leafs other than the OR. I don't know how it worked with 2wd trucks. There were recalls though and some involved changing the 3 leaf pack to 4 leaf packs. My suggestion is buy your own leaf springs. I got old man emu and will never go stock again. I even sold my stock leafs for 125.
  13. Oct 30, 2017 at 8:11 AM
    Pigpen
    Dan
    Northwest Montana
    My 4wd had the 3 leaf pack. I now have air bags and Dakar leafs with the OME AAL
    jpereira2[QUOTED] likes this.
  14. Oct 30, 2017 at 8:26 AM
    jpereira2
    Massachusetts
    I have the dakars as well. Great for towing, no bags just a weight distribution system.
  15. Oct 30, 2017 at 8:32 AM
    Pigpen
    Dan
    Northwest Montana
    The bags were my first suspension mod. I just never saw a good reason to remove them. The HD Dakar pack and air bags may be overkill. When I eventually buy a slide in camper, I may find the bags useful.
  16. Oct 30, 2017 at 8:33 AM
    Pigpen
    Dan
    Northwest Montana
    :threadjacked:
    end of thread hijack
  17. Oct 30, 2017 at 12:01 PM
    glk21c
    MD
    you're not kidding....but thanks, everyone, got the answers I was looking for.
  18. Oct 31, 2017 at 12:41 AM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    Sports have a 30mm sway bar and OR's have a 28mm sway bar to allow more travel off road use, but allow more body roll cornering on the street. Sports share the same linear rate springs, Hitachi struts and shocks, as the base models. OR's have progressive rate springs and Bilstein struts and shocks (which have variable valving :notsure: or just valving for off-road use). Also OR's come with 265/70R16 wheels while sports are 265/65R17, which are the same approx 30 1/2 inch wheel and tire diameter, but makes the OR have a "cushier" tire profile (in the same P rated tire), giving a softer ride at stock tire pressures, due to more side-wall to flex/compress.
