05-18 Tacoma bed Molle system (CaliRaisedLed)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaliRaisedLed, Mar 19, 2018.
  1. Apr 26, 2018 at 3:58 PM
    #141
    Tocobob
    Tocobob Well-Known Member
    I dig it! Great quality guys.
  2. Apr 26, 2018 at 4:02 PM
    #142
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Looks great thanks for the Post!:thumbsup:
  3. May 8, 2018 at 11:50 AM
    #143
    CaliRaisedLed
    Jake
    Texas (DFW)
    Great customer picture!
  4. May 9, 2018 at 5:27 PM
    #144
    ScorpioVI
    ScorpioVI IG: @scorpiovi.ig
    Alan
    San Jose, CA
    2016 Tacoma TRD Off Road DCLB (Quicksand)
    KMC XD800 Misfit 18x9 Wheels, Nitto Terra Grappler G2s 285/60R18, Leveling Kit
    @CaliRaisedLed
    Are you guys doing a video instruction on the cab molle panel? Seemed like quite the bag of bolts and spacers. Where do the included L brackets go?
  5. May 9, 2018 at 7:56 PM
    #145
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    We should have the install video tomorrow or Friday for you. But here is a quick guide for you.
    The hardware kit includes bolts for the following: 5 bolts for the top rail that also use 5 aluminum spacers and 5 washers. These are the smaller diameter ones. Then the larger ones are for the Molle panel itself. There should be 5 bolts, 5 nuts and 10 washers.
    First on a work bench assemble the panel. In the center of the two panels there are three 3/8" holes. One on the bottom, middle and top (not the smaller hole on the tab). Use 3 of the larger bolts, nuts and 6 washers to connect the panels. Should go: Bolt Head-> Washer -> Panel -> Panel -> Washer -> Nut, if that makes sense for the hardware assembly. IMPORTANT: The way you have the panel in the picture is the outside, the side you see when mounted. Make sure the bolts go in from the back and the nuts are on the outside. If this is done backwards the bolts will hit the bed.
    Now that they are connected you need to install the L brackets. They go in the bottom holes that are by themselves on the corners. IMPORTANT: These bolts also go in from the back like the others. The L bracket mounts on the back side of the panel (the short part). So it would go Bolt Head -> Washer -> L Bracket -> Molle Panel -> Washer -> Nut. Tighten these down snug but so you can adjust the height later on.
    Next we need to remove the bed bolts on the top of the bed.
    - 3rd Gen: There are 5 bolts spaces across the top, those come out. If you have the factory bed cover or the rail for it, that will go back in place later.
    - 2nd Gen: There are 5 bolts inside the rail system that hold the rail on, those need to come out, we will be re-installing the rail soon.
    After that you need to remove the front bed bolts. Take just the two in the front out.
    Now we can test fit the panel and adjust the L brackets. Set the panel in place and put in one of the smaller bolts on the top outside corners. Don't tighten them, this is just to hold the panel at the correct height. Now you can adjust the L Bracket height. Get them set, then take out the panel. Now tighten the bolts that hold on the L Bracket to Molle.
    * Now is the time to install any additional mounts like High Lift mounts or Quick Fists
    Almost done!
    Now we are going to install the panel. Put it back in place. Install the top hardware, leave loose.
    - 3rd Gen: Using the smaller bolts they should install like this Bolt Head -> Washer -> Panel -> Aluminum Spacer -> (Optional bed cover cross bar) -> Thread of Bed Nuts. Start with one on each outside corner, then the center ones.
    - 2nd Gen: Using the smaller bolts they should install like this Bolt Head -> Washer -> Panel -> Aluminum Spacer (they fit inside the rail) -> Rail -> Thread of Bed Nuts. Start with one on each outside corner, then the center ones.
    Next put the bed bolts back in and through the large holes on the L Brackets. Tighten these down. Then tighten the top bolts down.
    You are done, mount Molle bags, accessories, anything else you can think of!
  6. May 10, 2018 at 7:19 AM
    #146
    ScorpioVI
    Alan
    San Jose, CA
    @MojaveMadman Thanks! That’s pretty comprehensive! Will be mounting this Sunday.
    MojaveMadman[QUOTED] likes this.
  7. May 21, 2018 at 2:02 PM
    #147
    TheBlazer
    TheBlazer New Member
    2017 Quicksand Sport
    @MojaveMadman Any update on that video? I am still missing something with the L Bracket mounting points!
    Thanks!
  8. May 21, 2018 at 3:36 PM
    #148
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    I am out of town today and tomorrow. Shoot me a PM and I’ll help you get it installed.
  9. May 31, 2018 at 2:09 PM
    #149
    CaliRaisedLed
    Jake
    Texas (DFW)
    Great shot of a customers molle!
  10. Jun 1, 2018 at 8:43 PM
    #150
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    Anybody have any intel on who makes the tall beige bag in the May 8, 2018 post above? I'm trying to find a large bag for my panels and just get into search results for little molle pouches for ammo clips and radios. Where is a good supplier for large molle-compatible bags. Thanks in advance Tacoma brethren!
  11. Jun 1, 2018 at 10:02 PM
    #151
    Thompson486
    Thompson486 Well-Known Member
    Sherwood Park, AB
    2022 AC Off-Road Blue Crush
    It’s a Hydration bladder pouch (Not sure who makes that particular one though)
    You can probably get a similar one from many makers of tactical gear...
    Tactical Tailor, London Bridge Trading Co, Etc. Depends on how much you want to spend/what kindof quality you want.
    London Bridge stuff is top knotch.
    http://lbtinc.com/6080a
  12. Jun 5, 2018 at 11:24 AM
    #152
    CaliRaisedLed
    Jake
    Texas (DFW)
    I personally have that exact one! love it
    Thompson486[QUOTED] likes this.
  13. Jun 5, 2018 at 11:26 AM
    #153
    Thompson486
    Sherwood Park, AB
    Yeah LBT is always a good choice.
    I love my 1961A-R Rig.
  14. Jun 5, 2018 at 11:41 AM
    #154
    CaliRaisedLed
    Jake
    Texas (DFW)
    Looks super clean and there amazing quality
  15. Jun 5, 2018 at 11:44 AM
    #155
    Thompson486
    Sherwood Park, AB
    Top quality for sure!
    Ha ha I think that was the first time I used it in the field after I got it :p
  16. Jun 5, 2018 at 11:55 AM
    #156
    CaliRaisedLed
    Jake
    Texas (DFW)
    I was about to say it looked super clean :amen:
  17. Jun 7, 2018 at 11:45 AM
    #157
    CaliRaisedLed
    Jake
    Texas (DFW)
    Here’s a a picture of a customers full length molle system on both driver and passenger side
    SigSense and Thompson486 like this.
  18. Jun 8, 2018 at 11:31 AM
    #158
    CaliRaisedLed
    Jake
    Texas (DFW)
    New delivery from powder coat!
  19. Jun 12, 2018 at 1:55 PM
    #159
    CaliRaisedLed
    Jake
    Texas (DFW)
    Heres another customer utilizing his molle system
    SonnyBones likes this.
  20. Jun 20, 2018 at 11:02 AM
    #160
    CaliRaisedLed
    Jake
    Texas (DFW)
