05-20 TACOMA 8” LIFT
Discussion in 'Suspension' started by crank808, Aug 18, 2020.
  1. Aug 18, 2020 at 5:11 AM
    crank808
    crank808 [OP] Member
    Makana
    2012 4x4 PC 6”
    Here’s how to get an 8” lift on your second or third gen Tacoma for all who’s asking
    You need a PROCOMP 6” DB kit
    and Bilstein 5100 shocks
    PN:24-239370
    When you install the kit, put the 6” spacer on the STOCK coil and Bilsteins set to the highest clip.
    For the rear, a 5” block with the procomp add a leaf will completely level out the truck
    You will need SPC upper control arms or else the stock ucas will hit the coil.
    this setup completely clears 35s
  2. Aug 18, 2020 at 5:13 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Is it Friday already???
  3. Aug 18, 2020 at 5:14 AM
    crank808
    Makana
    2012 4x4 PC 6”
  4. Aug 18, 2020 at 5:21 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
  5. Aug 18, 2020 at 5:23 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    How much trimming to run 40's? Asking for a friend.
    TVH475 likes this.
  6. Aug 19, 2020 at 7:32 PM
    crank808
    Makana
    2012 4x4 PC 6”
    You might not be able to run 40s. Maybe a body mount chop might just clear them
  7. Aug 21, 2020 at 12:56 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Do you have pictures?
  8. Aug 23, 2020 at 4:41 AM
    crank808
    Makana
    2012 4x4 PC 6”
    PM ME
