05+ 2WD extra cab 5-lug Drop
Discussion in 'Street Trucks' started by Beefed Taco, Jun 20, 2010.
  1. Jun 20, 2010 at 9:07 PM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    This is noelsmykuya's truck. (on CT) I did the fully boxed weld in c- notch, the rear drop blocks with offset pins, and will be doing the front DJM arms tomorrow. He has the 4x4 leafs already in there. Plans are to go with the Sittin Sic drop coils a little later, (and possibly those spacers) as well as some 20" wheels.
    This wasn't just a slap n go project, I really spent some time getting the rear of this truck dialed in just right as far as the drive shaft goes and also the 3rd member and the stuff above it that it comes sooo close to at full compression.
    I made custom blocks that have the leaf pin set back 3/4" to keep the drive shaft from pushing into the trans too far and putting stress on the rubber carrier bearing. I also flipped the carrier bearing since the angle of both shafts were pretty bad. This things drives like a Caddy on glass, even at 80mph on the freeway.
    I'll have finished pics up after tomorrow.
    In the sweat cave at stock height
    virgin fame
    c-notch
    boxed (with a few drips I chose to leave for memories) wink_e8157a2c52c7e9ef467a36296f6b850e929d4fd1.gif
    stock tab gets cut and re welded flat for more clearance above the diff
    steel blocks with offset pins to keep driveshaft from pushing into trans
  2. Jun 21, 2010 at 6:24 AM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    Awesome job :headbang:
  3. Jun 21, 2010 at 6:28 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    Sick work Brian!!!! Can't wait to see finished pics!!
  4. Jun 21, 2010 at 8:48 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Thanks Brett.
    Thanks Aarn, I'll have some pics up when it's done. It'll really look good when he gets his tires and wheels on....a whole new truck.
  5. Jun 21, 2010 at 8:50 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Oh I'd say so! I'm trying to get me a 2wd pre-taco as a DD so might have ya throw me a drop together if I do.
  6. Jun 21, 2010 at 9:47 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Oh that pretaco will grow on you quick...I really liked these a lot when I notched them....all except the power steering I'm used to. haha.
  7. Jun 21, 2010 at 9:07 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Alright guys...he's officially low. Nothing leaves the shop unless it's pushing the limits.
    Final setup, DJM arms in front and Beefed parts in back in the way of custom welded and boxed c-notch and tapered steel 3-1/4" x 2-7/8" blocks (so they're a true 3" in the center) with offset pins, flipped carrier bearing and 4x4 leafs. Front shocks are stock and rears are QA1. Ridin' ass low until he gets his Sittin' Sic coils, but I like this look in a lowered truck. I almost prefer it.
  8. Jun 21, 2010 at 11:10 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    that back end is LOW! looking good!
  9. Jun 21, 2010 at 11:29 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    question? why not just air bag it?
  10. Jun 21, 2010 at 11:32 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    bags need more maintenance, more expensive to build and more complex to do it right. STATIC FTW. lol unless u got the money.
  11. Jun 21, 2010 at 11:54 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Yep, as low as you can go without crossmember notch and bed ridge trim.
    Money I'm sure, plus it's his DD, and I had it for 4 days.
    pretty much
    I made his 3" blocks with the pins moved back because I remembered how yours was, and it worked perfect. Then when I didn't think the 3" blocks were going to workout and I swapped the 2"ers in, I had those made already and the pins were centered. I decided to install them, and yep, the driveshaft was pushed in too far like yours was. It *may* have worked, but at 1/8" gap, it was a risk., plus when they're like that, the rubber in the carrier bearing has too much tension on it and my thoughts were it could wear prematurely. (something you don't have to worry about on your std cab) So I redid the blocks by filling the hole and redrilling it forward 3/4" to push the DS back, it worked great. Then today I put the 3"ers back because I was curious if he could do the 3"ers and wanted to see it lower...thank God it's over! Lotsa work on the rear of this biatch. :cool:
  12. Jun 21, 2010 at 11:55 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  13. Jun 22, 2010 at 6:59 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    imo, the rear would be the most if you are going the conventional route. As for me, I may be doing something very expensive (hybrid hydraulic/airbag set up).
  14. Jun 22, 2010 at 7:01 PM
    07TacoRidah
    Damn Beefy, NEVER a disappointment. GREAT job :headbang:
  15. Jun 23, 2010 at 12:18 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Hey thanks! Here's a better pic. It'll look super schweet when he gets his 20's on there, and gets the roll pan & removes that boat anchor of a hitch on back.:thumbsup:
  16. Jun 23, 2010 at 12:43 AM
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
    Looking good, love the stance, and great work as always. :thumbsup:
    Hey, let me know when he plans on getting rid of that hitch. I'd love to take it off his hands. :)
  17. Jun 23, 2010 at 2:03 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Yeah he's gonna ditch it. I told him he'd probably have real good luck selling it here on TW. You have first dibbs Steven. We really have to get your sliders on your truck soon too. I think a lot of guys will like what I'm going to do to the kickout/step, since my first style hasn't gotten the attention my newest style has. They've been sitting here next to me for too long and keep looking at me with that stink eye.
  18. Jun 23, 2010 at 6:49 AM
    07TacoRidah
    LMAO I know right? the tow looks like some kind of turd putter coming out.
  19. Jun 23, 2010 at 7:02 AM
    81shark
    81shark Well-Known Member
    yuck. but if he likes it....
  20. Jun 23, 2010 at 8:52 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Thanks. He does, and so do 50 million other people, just not you. He likes it as much as you like being lifted.
