05+ 4 bangers: 4.56, 4.88 info please
Discussion in '4 Cylinder' started by 08pretaco, Jan 25, 2011.
  1. Jan 25, 2011 at 8:43 AM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Ok so I know that I have PM'd almost everyone who has regeared their 4 cylinder but all the PM's are starting to blur and I wanted to get this all into a thread.
    So what tires are you running (size, brand ect)?
    What gears did you go with over the 4.10?
    What are your highway rpm's at whatever speed you drive?
    What is your gas mileage if you took a highway trip on a tank?
    I have 4.56's gears but now thinking I might want to go with 35's for offroad purposes and keep the 33's as my everyday tire.
    From some research:
    4.10 at 65 with stock tires: 2378
    4.10 at 65 with 255/85/16: 2191
    4.56 at 65 with 255/85/16: 2437
    4.56 at 65 with 35's: 2305
    4.88 at 65 with 255/85/16: 2608
    4.88 at 65 with 35's: 2467
    Used with trans ratio .81 with this calculator:
    http://www.justdifferentials.com/index.php?main_page=page&id=2&chapter=0
  2. Jan 25, 2011 at 9:04 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  3. Jan 25, 2011 at 9:47 AM
    danteisme
    danteisme Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    subbed cuz i wanna see some peoples answers
  4. Jan 25, 2011 at 11:20 AM
    08pretaco
    Oliver
    az
    Is that the correct overdrive ratio is is it .85?
    Edit: Nevermind .81 is correct just looked it up
  5. Jan 25, 2011 at 11:36 AM
    afd23a
    The Dynamo of Dixie
    According to cars.com the 05+ tacoma 5 speed manual tranny has these ratios:
    5-speed manual w/OD
    Specifications
    Transmission gear ratio (1st) [​IMG] 3.95
    Transmission gear ratio (2nd) [​IMG] 2.06
    Transmission gear ratio (3rd) [​IMG] 1.44
    Transmission gear ratio (4th) [​IMG] 1.00
    Transmission gear ratio (5th) [​IMG] .81
    Transmission gear ratio (reverse) [​IMG] 4.22
  6. Jan 25, 2011 at 6:32 PM
    ryber
    ryber Well-Known Member
    kitchener, ontario
    06 Reg Cab 4X4
    285/75/16 MTZ's.... OME lift(885s)...4:88 gears.... Front and rear ARB.... Homemade skids
    If your thinking of running 35s, chances are your going to end up with them in the end.
    Dont waist your time with 4;56 if 35s are in your future.
    I thought forsure the next gear thread by you would be " I LOVE MY 4:88s":p
    I'm actually thinking of going with 35s as well, the only reason im hesitant is with my 4:88s and 33s I love my low gear ratio, right now the truck is awesome in tight rocky terrain
  7. Jan 25, 2011 at 6:39 PM
    08pretaco
    Oliver
    az
    I know Ryan and you have been such a big help! I am just so stuck on this HUGE decision.
    I remember you were helping me with mileage and freeway driving. Can you tell me again please your info like speed, rpm, mileage?
  8. Jan 25, 2011 at 7:23 PM
    ryber
    kitchener, ontario
    06 Reg Cab 4X4
    Here ya go
    Running 285/75/16 MTZs with 4:88s
    Seem to be around 3000 rpms driving at 75 mph, judging by my gps as my speedo is off,
    And since my speedo is off I don't have an exact mpg number. But I seem to be getting 380 ish per tank and with having 488s and only 33s truck is over geared by about 18% this is including the tire size difference. So its the opposite as running a bigger tire where your reading slower and clocking less miles, in your reading faster and clocking more miles. My speedo is reading 88 when im driving 75.. If I take 380 and minus 18% I get 312ish.. this is of course estimating and averaging everything
    Wow thats the first time i calculated that out and thats pretty shitty I hope I'm wrong here..
    Of course the 380 is when my light comes on and theres still fuel in the tank.
    I really need to get that dakota digital box i got sitting my glovebox installed , you got me really wondering what my true mpgs are or get a scanguage would be the most accurate I guess
  9. Jan 25, 2011 at 7:47 PM
    08pretaco
    Oliver
    az
    Damn....that mileage sucks ass, I mean gas!
    Is there any way of double checking that at all? Because the logic sound right but I cannot imagine you getting 312/17.5= 18MPG which is terrible lol
  10. Jan 25, 2011 at 8:37 PM
    08pretaco
    Oliver
    az
    So i dis some math Idk if it make sense though. These numbers are from thw first post: 2608/2378= 1.1, then 380*.9= 342, then 342/17= 20 MPG
    I am only doing 17 because that's what I'm usually at when i fill up when my light comes on. The math don't really make sense but thw mpg outcome I like better lol
    Reason I did it this way is because:
    2378/2378= 1
    380x1= 380
    380/17= 22.35 which is what could be considered stock without modification.
    Another reason that makes sense to me:
    2191/2378= .92
    380x1.08= 410
    410/17= 24.1 Which is extremely on target with the gas mileage I get with my 33's and 4.10 ratio
    NVM the math gives 20 MPG going at 75 MPH which would make in untrue because you would be getting less than that....DAMN I thought I had something.
  11. Jan 29, 2011 at 10:43 PM
    08pretaco
    Oliver
    az
    I wish I could ride with a 4.56 and 4.88 to feel the difference and see if it is worth losing 4-6 mpg over it.
  12. Jan 29, 2011 at 10:48 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    4.88s with 265/75/16 (32")
    3k at 70 mph
    15-20 mpg. My in-town mpg increased but hwy decreased.
    Gears are the best thing I've done for my truck. Getting a new lift and 33" (305/70/16) in 2 weeks so that should help with the rpms. The power is night and day from stock.
  13. Jan 29, 2011 at 10:52 PM
    08pretaco
    Oliver
    az
    Looks like, since all the freeway driving the 4.56 is the way to go. Mileage will stay much more similar to now than with 4.88 and I will at least get my stock power back
