05 4dr 4wd Carrier Bearing and U Joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toysupra20, Sep 14, 2016.
  1. Sep 14, 2016 at 4:58 PM
    Toysupra20
    Toysupra20 [OP] New Member
    Daniel
    2005 Tacoma 4dr 4wd
    Front level kit
    Sup fellas. New to this particular forum. I have an 05 4dr 4wd Taco, with 180k miles. Just changed out the U Joints and Carrier Bearing myself today. Truck still has a little shutter in the drive shaft during acceleration/deceleration. Just looking for outside perspectives before I dive back in. New U joints could definitely use a little more grease. Also thinking the driveshaft might be off by a tooth. I marked it before removal, but it's not perfect. Input/feedback would be greatly appreciated. Truck has spacer/level kit on front, with oversized tires, so I know it's gonna ride like shit. But it shouldn't be shuttering the way it is. Thanks!
  2. Sep 14, 2016 at 5:38 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Possibly center carrier bearing / driveshaft support bearing
  3. Sep 14, 2016 at 8:04 PM
    Toysupra20
    Daniel
    2005 Tacoma 4dr 4wd
    Front level kit
    I just installed a new carrier bearing today, along with the U joints.
  4. Sep 14, 2016 at 8:20 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    These trucks are notorious for drive line vibes front and rear with a lift. When the truck is lifted the u-joint angles and cv angles change and create some chaos. Here are a few tips :
    1. Use washers as spacers to lower your carrier bearing a bit which will reduce the rear angle a bit. Lots of folks have good luck with this method, you can just add a couple of washers at a time until you find it resolves your issue.
    2. Rear axle shims, these will move the nose of your rear pinion up which also reduces the angles.
    3. If you shift into 4wd do any of the vibes go away ? If so it is highly likely that the needle bearing on the drivers side of the front diff is toast. East Coast Gear Supply makes a bushing to replace that bearing which generally resolves front end vibes.
    4. Check your front hubs / wheel bearings, they are also notorious for wearing out and will give you a good vibe before they self destruct. Jack up the front of the truck until the tires are off the ground, grab the tire at 12 and 6 o'clock and give it a firm shake. If there is any free play your hub is toast. There are a couple of guys on here that sell pre assembled complete replacement hubs at a really good deal.
    All of these are super common issues that nearly everyone runs into eventually...
  5. Sep 14, 2016 at 8:21 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You say the u joints could use more grease? Put in more grease
  6. Sep 15, 2016 at 1:04 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Shudder on acceleration is the usual Tacoma axle wrap.
