05 4x4 offroad six speed manual trans oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kagmyster00, Sep 16, 2009.
  1. Sep 16, 2009 at 6:25 PM
    kagmyster00
    kagmyster00 [OP] Well-Known Member
    Mark
    05AccessOffroad
    was wondering if i would be able to do this or do you need special tools to change the transmission fluid any suggestions
  2. Sep 16, 2009 at 6:26 PM
    cullensheffiled
    cullensheffiled Active Member
    cullen
    georgia
    05 trd
    3 inch ome lift kit k & n air intake 33 inch pro come all terrain tires 17 inch helo rims jvc bongovi headunit 2 stage 3 rockford fosgates and 2000 watt rockford fosgat amp
    u wouldnt need any speacial tools
  3. Sep 16, 2009 at 6:43 PM
    kagmyster00
    Mark
    05AccessOffroad
    dont know what year but i remember seeing that some transmissions are sealed and needed the right pressure to measure the fluid level is that just the autos? and would the Castrol syntec 75w 90 be a good oil to use ive always used and trusted castrol oils
  4. Sep 17, 2009 at 5:40 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Couple Qts of your preferred 75w-90. You'll need a cheap pump and hose to refill and a 24mm socket (If I remember correctly). Loosen filler plug on mid section of tranny facing drivers side. Loosen drain plug on bottom of tranny. Drain. Tighten drain plug. pump in oil. Tighten fill plug. Open beer.
    Search around for full writeup.
  5. Sep 18, 2009 at 1:33 PM
    kagmyster00
    Mark
    05AccessOffroad
    ok i finished changing the trans oil put castrol syntec 75W 90 and after i was done i went out for a test drive to make sure everything was ok and everything was good except when i went to shift to 3rd it started to grind for a second and i slowed down and when i got to 3rd it did it again then after awhile of riding i guess when it got warm it was fine it is not cold here like low 60s at night was wondering what could be causing this?
  6. Sep 18, 2009 at 3:14 PM
    akwagon
    akwagon Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    Check your oil level
  7. Oct 5, 2009 at 11:39 AM
    kagmyster00
    Mark
    05AccessOffroad
    ok took out the castrol shit and put in Redline MT-90 and wow smooth as a babys ass no problems at all i think the castrol was to slippery the Redline was amazing great stuff
