05+ 5 Lug to 6 Lug Suspension Conversion
Discussion in 'Suspension' started by 671born, Nov 3, 2010.
  1. Nov 3, 2010 at 7:19 AM
    671born
    671born [OP] Well-Known Member
    Patrick
    Guam
    08 Access Cab 5-Lug
    Audio, Blacked out Badges
    What's up TW peeps. Just got a quick question. I know that some rear components for the 6 Lug can be used for a 5 Lug. Are there any suspension components, specifically that will provide lift, that can be used for the front? Coilovers, coils, adjustable shocks? It's a shame that 5 lugs' options are so limited so I just wanted to know if this is possible. Sorry for the noob question. Thanks.
  2. Nov 3, 2010 at 7:24 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Not without some cutting and welding.
  3. Nov 3, 2010 at 7:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    For a 5 lug - it's called "SOA" or Spring Over Axle conversion. And like 98tacoma27 already said - lots of work.
    What exactly are you trying to accomplish by lifting it? Looks? Capabilities? Bigger tires?
  4. Nov 3, 2010 at 8:03 AM
    671born
    Patrick
    Guam
    08 Access Cab 5-Lug
    I guess all of the above. Haha. Want the look and tires for sure but at the same time want to increase capability and functionality...I don't want to worry every time I approach a speed bump or pothole post lift. I've heard bad things about spacers and just looking to avoid it if possible. But going UCAs and COs will cost an arm and a leg. Still can't decide. Thanks for the info.
  5. Nov 3, 2010 at 1:57 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i know a 5 lug 05+ that is running SAWs coilovers up front...
    you may want to hit up Sway Away for a part number...
