05 6 speed issues.. tell me what you think?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by supadave888, May 23, 2011.
  1. May 23, 2011 at 4:36 PM
    supadave888
    supadave888 [OP] Well-Known Member
    morgan city La
    4x4 trd sr5
    ok fellas toyota really got me scratching my head here.. i drive a 05 double cab 4x4 6 spd and started having trouble with getting the tranny in gear.. it just wont go in gear so it makes me think its the sycros.. but the tranny shop said it could either be the forks or the sycro and dont know till they get in it but im not sure if you wanna know the cost.. 400 to take it in and out no matter what it is.. 2800 if its the sycro and 1100 if its the forks but damn it this seems rediculous to me!!!!!!!!! sorry just felt like i needed to vent.. i thought these 6 speeds were tough.. trucks got 108,000 miles.. what are yall thoughts?
  2. May 23, 2011 at 5:35 PM
    ice.xiv
    ice.xiv Member
    06 TRD Access Cab 4x4 6Spd
    Cheapest option first: change your tranny fluid. I've used Redline and Silkolene products without any problems. I believe the Taco has a magnet on the drain plug so you'll be able to see how much metal has collected. It should be really fine shavings, that's completely normal.
    When was the last time your tranny fluid was changed?
  3. May 23, 2011 at 6:08 PM
    supadave888
    morgan city La
    4x4 trd sr5
    im pretty sure its more than just that.. but im gonna take it out the truck and have a buddie take it down and see whats the issue but idk if its been changed before i bought it but ive never changed it since i own it
  4. May 23, 2011 at 6:17 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, Sickspeed shift knob, mud flap delete, white lithium grease mod for creaky clutch pedal
    $2800?! Christ on a cracker!
  5. May 23, 2011 at 6:28 PM
    supadave888
    morgan city La
    4x4 trd sr5
    pretty much.. id be 3200 total.. anyone know about these sycronizers?
  6. May 23, 2011 at 6:33 PM
    toytaco1
    toytaco1 Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    Had similar issue on my 05 A/C 6 speed was driving went to put it in second and didnt go. Towed it home knew it was the forks bought a new one from toyota parts online which was like 100 and some bucks and while I was at it bought a new clutch for like 140 and did the install with the help of my dad and his friend. Total cost was just parts, when I pulled the forks half the teeth were bent in and wouldnt engage the clutch the replacement was thicker and more heavy duty. The stock pressure plate was thin and flimsy might be your problem but 1100 ouch
