05 Auto to Manual 6sp Swap!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ronster73, May 14, 2015.
  1. May 14, 2015 at 2:08 AM
    ronster73
    ronster73 [OP] Active Member
    Ronnie
    Kailua
    White Taco 4X4
    So I'm looking for some information. I am 3/4 ways thru this swap, but there are no mount holes for my clutch pedal or Ebrake set up. I have the mount bracket for my clutch pedal, but it was tack welded on the truck (it was removed). I just don't know where the exact location it has to be. Has anyone performed this swap and do you have pictures so I know exactly where I have to bolt these things in whether it is tack welding or just nut and bolt? Any information would be great besides people telling me where the search box is...I just spent 2 hours looking and couldn't fine anything. I have everything from a donor truck, but I did not remove the clutch pedal or the ebrake set up. So i don't know where there exact locations are supposed to be. I guess even pictures of someone's stock set up would help me out a bit...w/the dash off of course so I can see everything. Thanks in advance..PM under my username would be great. if not I guess I'll have to keep checking this post. Thanks Ronnie
  2. May 14, 2015 at 4:21 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    That's going to be a tough one. I did have a 6 speed tacoma taken completely apart a few years back. Your best bet is to find one and crawl under the dash, maybe take some measurements
  3. May 14, 2015 at 6:41 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    OP, I'm not going to pull my dash off for you, but I can try to get some pictures from underneath. Also, if there are any particular measurements you need from a given reference point, I could do that, too. Just let me know.
    Could you run the pushrod for the clutch from the cylinder, back through the firewall and use that as a reference point?
  4. May 14, 2015 at 1:55 PM
    ronster73
    Ronnie
    Kailua
    White Taco 4X4
    Obscurotron....any pics would be greatly appreciated! I guess from the break booster/pedal.
    357sig Thanks...
  5. May 15, 2015 at 6:40 AM
    obscurotron
    N. Nevada
    '14 DCSB 4x4
    Alright, I'll try to get that for you after I'm done running around this morning.
  6. May 19, 2015 at 3:04 PM
    ronster73
    Ronnie
    Kailua
    White Taco 4X4
    Obscurotron: were you able to take any pics? you can text them to me...8084790182 thanks Ronnie
  7. Oct 1, 2017 at 10:46 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I know this is old but anything ever come of this?
