05+ Climate control back light and face color change
Discussion in 'Lighting' started by Jones, Feb 1, 2011.
  1. Dec 11, 2011 at 4:25 AM
    #41
    Jones
    Jones [OP] Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
  2. Jan 18, 2012 at 6:54 PM
    #42
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i want this done!!! but i already messed one up soooo
  3. Jun 18, 2012 at 5:33 PM
    #43
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    I'm researching how to make this 125+ colors that are controllable by multiple means. Any other tips for changing out the CD display LEDs besides bending the display back? I have an extra radio to experiment with, but it's a 6-CD so I'd like to preserve it and use it later if possible :D
    Also, how did your steering wheel LEDs go? I haven't seen that one before!
  4. Jun 18, 2012 at 6:47 PM
    #44
    Jones
    Texas DFW
    I didn't bend the screen back at all. I bent a soldering iron tip 90 degrees, (when the iron was hot) to get to the back of the LED. There is some flex in the screen's needles. I would put some tape on the underside of the screen to be safe and prevent an accident with the iron getting to close to the screen. It is a pretty tight fit.
    The steering wheel LEDs are pretty easy. It is three of the same ones that are used on the dash's gauges.
  5. Jun 25, 2012 at 5:40 AM
    #45
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Jones u wanna do this for me I'll pay you
  6. Jun 25, 2012 at 6:07 AM
    #46
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i already asked :p
  7. Jun 25, 2012 at 6:18 AM
    #47
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I did 2 he didn't answer my pm
  8. Jul 13, 2012 at 8:10 PM
    #48
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Ok so he answered me I set him mine did it in a day an sent it back it's awsome can't wait for it to come in
  9. Jul 14, 2012 at 8:14 AM
    #49
    AsianAnts
    AnT
    I sent him pm too D:..
  10. Jul 25, 2012 at 3:35 PM
    #50
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    so you used acetone on the A/C and recirculate buttons to get the amber off, why not just use that too for the other controls? I'm just wondering cause it seems like the easiest way of removing the amber film, also, to get yours blue, you changed out the LEDs to blue right? so in their stock form they're white?
  11. Jul 25, 2012 at 4:36 PM
    #51
    Jones
    Texas DFW
    The two parts are made differently. The dials have a clear base that is about 1/4 inch thick, then the silver dials are glued on top of the clear base of the dials. The back of the silver dial's cover has the amber coloring, so it is in between the outside part of the silver dials and the clear base of the dials.
    The best way to get the blue color is to color the backside with blue sharpie. Changing the bulbs to blue messes up the red dial for the heat.
    In stock form after taking out the amber, the incandescent bulbs have a yellowish light. Changing to a white LEDs makes it look better.
  12. Jul 26, 2012 at 12:12 PM
    #52
    Toy Yoda
    Garrett
    06 DCLB
    ahh okay cool, i gotcha, ill have to mess around with this, thanks for the great write up man
  13. Sep 3, 2012 at 10:53 AM
    #53
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    That is awesome man :thumbsup: from Canada.
  14. Sep 3, 2012 at 11:00 AM
    #54
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Doing this to my truck today...well startin on my extra controls
  15. Sep 3, 2012 at 11:02 AM
    #55
    Jones
    Texas DFW
    Nice. Good luck. Send me a PM if you need to or post it.
    A while back I switched all my LEDs to white and took all the blue out on the A/C controls.
    No picture that I can find. I will find one and post it up later today.
  16. Sep 3, 2012 at 11:13 AM
    #56
    Jerez
    Rod
    Ontario Ranch
    Estock
    Awesome :) thanks man!!
  17. Sep 3, 2012 at 11:21 AM
    #57
    Jerez
    Rod
    Ontario Ranch
    Estock
    Only thing tho, I think I'm going to custom make my own small board to add to the inside for extra lighting...:spy:
  18. Sep 3, 2012 at 11:42 AM
    #58
    Jones
    Texas DFW
    I was thinking something similar to that too. I might have to learn to make pcb's next.
  19. Sep 3, 2012 at 11:48 AM
    #59
    Jerez
    Rod
    Ontario Ranch
    Estock
    I learned how to cut, ecth and make them in school....but I don't have the materials necessery to make them :( so I was thinking of using some small ones they sell at this store oh here and merging them together on the inside to complete the whole "background" lighting
    Like blue LEDs and red ones on the temp part
  20. Sep 3, 2012 at 7:40 PM
    #60
    Jerez
    Rod
    Ontario Ranch
    Estock
    Well I got it to here...
    I soldered some LEDs in place for now...you can kinda see them
    Slowly killing the last of the orange
    you sir are a genius...i would have never had the balls to try this...lol
