05+ DRL (Daytime Running Lights) Install OEM
Discussion in 'Technical Chat' started by 007Tacoma, May 10, 2007.
  1. Jan 12, 2021 at 12:43 PM
    #581
    usadaytrader
    usadaytrader Well-Known Member
    I am confused. I've owned this truck since brand new. I like this mod, by buying and installing two parts, but is there a way to also turn off the DRLs if I want to drive incognito?
  2. Jan 12, 2021 at 2:53 PM
    #582
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Sorry, i think I misunderstood you so disregard my reply. I don't know how to control the DRL in this mod, hopefully someone else can chime in.
    I got the same DRL result but i tapped into my corner marker lights.
  3. Mar 17, 2021 at 1:51 PM
    #583
    Rektless4x4
    Rektless4x4 New Member
    07 Toyota Tacoma TRD Off Road
    Stock
    Just completed this mod. Great write up. Easy to follow. :thumbsup:
  4. Aug 4, 2022 at 6:15 PM
    #584
    ibilintuc
    ibilintuc Member
    2005 PreRunner
    Stock 95k miles
    Did this. Looks good. OEM, too! EasyPeasy. Thank you 007Tacoma!
    RA77 likes this.
  5. Aug 4, 2022 at 6:46 PM
    #585
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I haven't been here in quite some time but I did the DRL to my '09 Taco shortly after I bought it and still have it. At some point later there was a post about the DRL bulbs burning the amber part of the light which apparently was plastic. My DRL were burned. I don't know if it was in this thread or another but it said that Toyota had a "silent" warranty that took care of this. I took my truck to my dealer and they replaced both headlamp assemblies no charge with ones that have amber glass and no questions asked even though my truck did not come new with DRL.
  6. Aug 5, 2022 at 6:21 AM
    #586
    sventi
    sventi Active Member
    NH
    2010 Tacoma AC 4x4
    RTT
    Interesting to know that they will still swap these. Are you able to tell the difference between the glass compared to the plastic version? I'm not sure what my truck has.
  7. Aug 5, 2022 at 7:02 AM
    #587
    Rickochet
    Rick
    Kentucky
    I don't know if they will still do this or not. I can't remember when I did this but it was many years ago. I mainly wanted to alert you that you might see the plastic amber lens burn over time. I don't know if you can tell the difference between the glass ones and the plastic. And, I don't know what after market ones from places like Rock Auto have. I do remember that the dealer showed the replacement cost as about $1200 to change the light assemblies.
  8. Aug 5, 2022 at 11:08 AM
    #588
    Rickochet
    Rick
    Kentucky
    I noticed something when I went out to use my truck this morning. IIRC the original lights that burned were behind a rectangular orange plastic inside the glass. The new ones use clear glass with an amber bulb. So, if your DRL's have clear glass and an amber bulb you are ok. If plastic you will get a round dark burn spot about the size of a penny eventually.
  9. Aug 5, 2022 at 11:50 AM
    #589
    sventi
    NH
    2010 Tacoma AC 4x4
    RTT
    Thanks for reporting back. Mine have a clear-ish lens in front of an amber bulb. The plastic or glass has a bit of an orange hue to it but is mostly clear. Thinking these are the newer style.
  10. Aug 20, 2022 at 8:10 PM
    #590
    TacoAJ
    TacoAJ Well-Known Member
    AJ
    2006 Black Tacoma
    Can anyone confirm if the part numbers are still the same? I searched them to order and the jumper came back as “hazard warning flasher”. Is this correct?
  11. Aug 20, 2022 at 9:29 PM
    #591
    ibilintuc
    ibilintuc Member
    2005 PreRunner
    Stock 95k miles
    I purchased mine from a dealership, via ebay.
    Search "Toyota Tacoma Daytime Running Light Kit DRL Genuine OEM OE"
    Listing was still active as of 08/20/2022.
    ...and, yes, the black box is a flasher.
  12. Sep 24, 2022 at 7:43 PM
    #592
    emcee_pern
    emcee_pern New Member
    2007 V6 SR5 PreRunner
    I know this is an old thread but wanted to see if anyone knew if the replacement flasher in this mod is LED compatible or if there is an aftermarket flasher that is for the DRL setup that is LED compatible. I did my best to read through the thread but didn't see anything addressing this. I'd like to add some aftermarket lights with LED DRLs but would prefer a clean install rather than having to put in adapters or resistors if I can get away with it.
  13. Sep 28, 2022 at 10:35 AM
    #593
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I don’t believe so. Just replace and use LEDS then live with your turn signals hyper-flashing. It’s not that big of a deal and the upgrade to LEDS far outweighs the hyper-flash. That’s what I did and have no regrets. Although I don’t recommend using anything other than standard halogen bulbs in the stock housing. Then upgrading to an LED type DRL. Good luck with whatever you choose.
    emcee_pern[QUOTED] likes this.
  14. Sep 28, 2022 at 10:58 AM
    #594
    emcee_pern
    Thanks for the reply. What research I've been able to do kind of confirmed the lack of the 12-pin LED flasher. My truck didn't come with factory DRL so I've already replaced the 8-pin flasher and put LED bulbs in the factory lights and that works fine without hyper flashing. I have my eyes on the Alpharex Pro Series headlights and they make a converter for trucks without DRL which I *think* will work if I just leave in the 8-pin flasher. I was just trying to see if I could keep things simpler and not have to deal with the extra wiring under the hood.
    R0dzilla75[QUOTED] likes this.
  15. Nov 21, 2022 at 10:08 AM
    #595
    dscoobydoo
    dscoobydoo New Member
    PNW
    2011 Work taco, 2017 TRD personal taco
    Wheels/Bed liner/ Front Camera/
    2011 Tacoma WITH DRL, trying to remove them: i did the reverse of 007's write-up, and replaced the jumper and DRL relay with the Non-DRL Flasher# 81980-02030 and jumper #82671-30360.
    Now I don't have DRL's AND no front turn signals.
    Everything else works 100%.
    I can feel the new relay working when I push the hazard lights button.
    All fuses good.
    Trying to find the solution.
    I don't want to do the "cut the green/red wire mod", as I don't want DRL's, but if that is the only solution then I will.
    Any asssistance/solution is greatly appreciated
  16. Mar 6, 2023 at 4:46 PM
    #596
    tacoma-bless
    tacoma-bless New Member
    2007 Tacoma TRD Sport
    The first post stated that for 2006-2009 Tacomas, the jumper isn't needed. I have a 2007 TRD sport from the USA but I live in canada. Can I purchase just the relay and plug it into my fuse block to enable my DRL's? Someone please advise. Thanks
  17. Mar 6, 2023 at 5:12 PM
    #597
    TacoAJ
    AJ
    2006 Black Tacoma
    the first post says this…”This installation also works on 2003-2009 4Runners, but you will not use the jumper. You only need the relay Part # 82241-04030”
    I dont see it saying anything about 06-09 Tacomas
  18. Mar 6, 2023 at 5:27 PM
    #598
    tacoma-bless
    Thanks for the clarification. I mis-read that part. I will therefore get both items. On another note, the US dealer wired the low beams using a relay so when you switch on the ignition, the low beams come on. How do i remove this setup when I install this mod? This is my first Tacoma, so I'm working to get it set up as be Canadian standards. Any steps there will be greatly appreciated Thanks!
  19. Mar 6, 2023 at 5:53 PM
    #599
    tacoma-bless
    One other question: If I replace the fuse block with one from a Canadian Tacoma, would the DRL work? Anyone ever did that? I have access to a used one from a Canadian Tacoma. Thanks
  20. Mar 16, 2023 at 3:25 PM
    #600
    RA77
    RA77 Active Member
    Russell
    Lawrenceville, GA
    07 Tacoma PR Sport
    From the Royal Toyota site on eBay.
    These are the Genuine Toyota Relay & Jumper Wire used on the following models:
    2005 - 2012 Tacoma (Not Applicable for Tacoma's that came with Factory Tow Package or Factory Daytime Running Light System)
    I have a factory tow package. Bummer!
