05+ DRL (Daytime Running Lights) Install OEM
Discussion in 'Technical Chat' started by 007Tacoma, May 10, 2007.
  1. Mar 20, 2023 at 5:17 PM
    #601
    tacoma-bless
    tacoma-bless New Member
    2007 Tacoma TRD Sport
    Thanks!!
    I went to a salvage yard and took the parts off a canadian tacoma. everything works as it should now
  2. Jul 26, 2023 at 2:48 PM
    #602
    Spidious
    Spidious 2006 Tacoma SR5
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Forward & reverse camera monitoring Bed Mat Tyger Black Tonneau Cover Tyger Sport Bar, 36" led light bar Hikity Android Car Radio Pro grill with lights Sport hood Cold air intake Sprint Booster throttle controller Flip down bed extender 265/75R15 tires 2"spacers New led tail lights Internal/external thermometer Chrome Bullbar Chrome step tubes LED F&R led turn lights
    Finally did the mod. Got the harness and larger flasher from Toyota through my son. Since he works at Hyundai/Toyota. Super easy to do. Installed led lights with built in resistors at the same time. They flash normally and work exactly like DRL lights should work. Thanks !
    3.4PDM likes this.
  3. Apr 15, 2024 at 3:16 PM
    #603
    77thor
    77thor Driver
    Fred
    Milwaukee, WI
    2010 Tacoma SR5
    I see that this is an OLD thread... Maybe I should've started a new one but here goes...
    I want to replace my OEM Flasher Relay with an LED Flasher Relay (CF18, LM449, 8-pin) that I got on eBay, just to fix the hyper-flashing.
    My Taco is a 2010 with factory DRL's and I want to keep them, so I'm assuming that all I need to do is replace the flasher...
    and the jumper that was referred to in this thread would not be required.
    Is my assumption correct?
    Can anybody verify this???
  4. Apr 15, 2024 at 5:59 PM
    #604
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    welcome
    Diode Dynamic has a flasher but it doesn't work with DRL
    I have no faith in an unknown fleabay doodad if DD can't make it work
  5. Apr 20, 2024 at 8:49 AM
    #605
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Again, just live with the hyperflashing. It’s not that bad plus have peace of mind that you aren’t melting your headlight housing from the inside with incandescent. The LEDs look crazy good IMO.
  6. Sep 10, 2024 at 11:32 PM
    #606
    apbright
    apbright Well-Known Member
    Aaron
    2007 Silver Tacoma Base
  7. Sep 11, 2024 at 7:15 AM
    #607
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    I did this mod, took about an hour total. This fixed the hyper flash on my 2010 when I installed my led switch backs. No issues going on 5+ years now.
    Go easy with the dremel/file and plug in often to check, at a certain try it will just flash normal.
    https://www.youtube.com/watch?v=30DQI7hzo0Y
    apbright likes this.
  8. Nov 13, 2024 at 12:32 AM
    #608
    Jasonvw0
    Jasonvw0 New Member
    2008 SILVER TACOMA
    None
    Does anyone know if this process works for an aftermarket headlight unit? It comes with drl but it only works if the truck has the factory drl.
    I have an 08 Tacoma
