05 head lights replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Jun 30, 2014.
  1. Jun 30, 2014 at 9:54 AM
    evile
    evile [OP] Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    So at 125k and being replaced once under warranty both headlamps are fogged over and melted over the turn signal / dlr and I want new ones but don't want to pay oem price.
    Any suggestions for aftermarket?
  2. Jun 30, 2014 at 10:13 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I would look for an OEM style replacement instead of some ricey looking crap but thats me. Maybe look in for sale section for someone selling take offs when the rice their shit.
  3. Jun 30, 2014 at 10:15 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  4. Jul 13, 2014 at 10:48 PM
    dsignrguy
    dsignrguy Member
    Ros Angeres
    indigooooooooo off-road
    or take it back to toyota and have them replaced for free under the new extended (no mileage limit) TSB, I'll buy a set of whatever you want, and we trade. (as long as they wonk in my 06 without DTRL)
  5. Jul 13, 2014 at 10:51 PM
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    My 05 has fogged up headlights too. Looking for that clear crisp performance and look. TSB? Time to do some research.
  6. Jul 14, 2014 at 5:21 AM
    evile
    Orlando, Fl
    Do you have a link for this tsb?
  7. Jul 14, 2014 at 5:31 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
  8. Jul 14, 2014 at 5:32 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
  9. Jul 14, 2014 at 5:43 AM
    ARtaco
    ARtaco Active Member
    North East Arkansas
    '11 DC BLK SR5 4x4 3" lift ARB bull bar
    ARB bull bar, camper shell, warn winch, Allpro sliders, allpro pack rack
    Look through this thread for the headlight tsb info.
  10. Jul 14, 2014 at 5:59 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    I dont remember a tsb on the headlight itself. But they do have one for the turn signal that gets to hot and melts. If it melts the headlights they will replace it
  11. Jul 14, 2014 at 7:38 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There is a new warranty on DRL melting lenses , they replace the entire headlight assembly , couple new threads on it
  12. Jul 14, 2014 at 8:47 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Am i missing something? If it's under warranty why arent you just getting new factory ones... OEM price should not be something you are discussing in this situation:confused::confused:
  13. Jul 14, 2014 at 11:34 AM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    I just replaced mine as I got tired of polishing them. While I normally buy only Toyota Parts I decided to try the aftermarket this time. I purchased mine online from AM-Autoparts for $126.15 a pair. They came quickly and looked good. They came with bulbs too but I used my existing bulbs as they are brighter than stock.
    Before you install them take a reference shot at your garage door or some object and mark the beam. Also go to the Toyota house and purchased some plastic tabs as you will bugger up the old ones.
    Then proceed with installation. The 10mm bolt on the side is a bugger and I removed one plastic tab and one bolt on each fender and pushed the edge of the moulding to get to that 10 mm bolt. Otherwise it is just like the example instructions posted above via you tube,
    After the installation I had to adjust the beam vertically on each headlight, your results may vary. I did not silicon seal the seams of each headlight but if they fog up I will. Took about an hour to perform the installation.
    I have been impressed with the stock style headlights as they put out an impressive beam with those monster parabolic reflectors. I was not willing to install the aftermarket Halo units as they do not put out as much light.
    Good Luck on your installation.
    Spock Out!
  14. Jul 16, 2014 at 12:06 PM
    evile
    Orlando, Fl
    someone show me where this tsb or extended warrenty info is located? I have access to Alldata and all of the recalls and TSBs toyota publishes and its not listed
    ETA: found it in all data. its only covered 3year or 36k miles so I am SOL
  15. Jul 16, 2014 at 11:05 PM
    dsignrguy
    dsignrguy Member
    Ros Angeres
    No, not SOL. they updated it, and now consider it a safety issue. It is till just a TSB, but no longer has mileage/warranty restraints. just go to the dealer before 2015 and you're good.
  16. Jul 16, 2014 at 11:10 PM
    dsignrguy
    dsignrguy Member
    Ros Angeres
  17. Aug 20, 2014 at 5:16 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
