05 headgasket or water pump?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfcarpenter, May 29, 2018.
  1. Jun 2, 2018 at 7:14 PM
    SpeedwayBlues
    SpeedwayBlues Well-Known Member
    '07 Speedway Blue Double Cab Long bed
    Sound system (in work)
    I think that's pretty safe to say you found your culprit
  2. Jun 2, 2018 at 7:28 PM
    cfcarpenter
    cfcarpenter [OP] Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    I wish you were right my friend, still bubbling over. I hate to say it but out comes the motor.
  3. Jun 2, 2018 at 7:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A defective thermostat is not going to cause a coolant loss. Just saying...
  4. Jun 2, 2018 at 7:33 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    i had the same issue on my 06 i did the head gasket in the truck
  5. Jun 2, 2018 at 8:16 PM
    WILLIAM ROBERT
    WILLIAM ROBERT Well-Known Member
    Edmonton
    it's blue
    Sounds like head gasket leaking. Sometimes the gasket fails in such a way that the compression from the cylinder enters the coolant system. This can cause air lock which may make your heater lines and tad lines go cold, this will also cause the overflow to bubble over and would explain where you are loosing your coolant. Some times it is hard to diagnose because the gasket has failed in such a way that the engine needs to be hot. Most people do compression and coolant pressure checks when the engine is cool and easier to work on. Try doing a cylinder pressure test when the engine is warm, this may help you find out which cylinder is the cause. Or pull both heads off and change both gaskets. If you do pull heads, I would recommend taking them to a machine shop to have them decked. This service is fairly cheap and while ensure that you don’t put a warped head back on.
  6. Jun 2, 2018 at 9:41 PM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    After a test run it bubbles over, going to pull the motor next week when I Finish this 4runner. Doing both heads. Next question is factory gaskets or fellpros?
  7. Jun 3, 2018 at 3:23 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Jimmy H How are ya doing? He said the radiator was hot on top and cold on the bottom, thats sometimes a bad thermostat. I figure thats a cheap place to start glad its fixed....
  8. Jun 3, 2018 at 6:14 AM
    SpeedwayBlues
    So how does your oil look? I asked the other day but people were heading towards the water pump as the problem. If your head gasket's leaking, one of the things that can happen is you can get coolant in the oil, which makes the oil cloudy or milky. I had a leaking intake gasket on an old car that did the same thing. When it first started it was just a few wisps but as it got worse, it churned the entire oil system into chocolate ice cream.
  9. Jun 3, 2018 at 7:54 AM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Oil looks as it should. From my understanding 05-06 had a poor head or head gasket design (not sure what one hopefully some one can touch on that) in a 15 min drive the truck pushed coolant into the over flow and out of it from it being at half full when I left.
    I’m sure this will get mixed feelings but should I buy factory Toyota head gaskets or is there some thing better? I was thinking on doing arp head studs what are some thoughts on that?
  10. Jun 3, 2018 at 4:19 PM
    DCLBFTW
    Minnesota
    06 dclb
    I did my head gasket in the truck
  11. Jun 25, 2018 at 9:05 PM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Well it was the head gasket. Pulled it out Wednesday got it all tore down. Had the heads machined. Replaced the gaskets and head bolts with factory Toyota parts. Had it all back in and running Sunday morning. So far no bubbles and is running like it should. I didn’t take very many pictures but in the scheme of things it’s just all nuts and bolts went pretty smooth.
