05 Honda 400ex question
Discussion in 'All Terrain Vehicles' started by SRTchris, Feb 27, 2011.
  1. Mar 15, 2011 at 3:40 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    listen to this guy, sorry didnt see this post before i posted mine
  2. Mar 20, 2011 at 9:25 AM
    SRTchris
    SRTchris [OP] Well-Known Member
    South Ohio
    07 TRD Sport Access 6speed
    Stock
    So put seafoam in it. Still nothing.
    Pulled carb back off again today. And ran carb cleaner and a Tip Cleaner tool through it.
    Put it back together, its better, but still does it.
    I rode it yesterday on some trails. The part that gets me is, when we first got out, I would go WOT and it would start cutting out, then all of a sudden it would run perfectly fine, all in the same gear.
    At first, it would run fine in 1st gear, but the other gears would have the problem.
    My thought it with this way, it almost seems ignition problem. With it being all in one WOT time in the gear, where it would cut out, then go back to normal.
    But towards the end of the day of riding last night, it got worse and worse, where I coudlnt even be low RPMS in higher gears with out it cutting out. Could only go like maybe 30mph.
    I ordered a KN air filter, wont be here until next week. And I think Im just going to go ahead and make the purchase for a Hot Shot CDI Box.
  3. Mar 20, 2011 at 9:52 AM
    SRTchris
    South Ohio
    Stock
    Or even TPS maybe...
  4. Mar 20, 2011 at 9:52 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    its gotta be something with the carb... might be worth pulling the carb and taking to a repair shop to see if they can diagnose the problem.
  5. Mar 21, 2011 at 1:10 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock,2008 Reg. Cab 4x4
    locker,mud tires, lifted, toolbox
    Tried running sea foam through it? I bought a kfx400 that had sat for awhile, and it had the same problems you are describing. Ran can of sea foam through it in two tanks, and it worked itself out.
    EDIT: NM, just read you tried that.
  6. Mar 21, 2011 at 1:13 PM
    97yota4wd
    Eric
    Mesa, AZ
    did you drain the gas tank and clean it out?
  7. Mar 21, 2011 at 1:34 PM
    SRTchris
    South Ohio
    Stock
    No, have not done that.
    When we first got it, it was pretty low on gas. So I just filled it up with Shell 93.
    Then Seafoam has been in it. Since you guys told me to run it in the tank.
    Guess next thing would be drain tank and clean it out.
  8. Mar 21, 2011 at 1:47 PM
    97yota4wd
    Eric
    Mesa, AZ
    when you drain the tank and clean it out clean the carb again since stuff would have been sucked back in there, you can also put a fuel filter in the gas line
  9. Mar 30, 2011 at 8:25 PM
    SRTchris
    South Ohio
    Stock
    Ok, heres where Im at on this.
    Stock filter, i believe, paper filter with foam outter. Anyways, it was a little wet. Dried it out, but still was a little wet.
    Bought a KN filter for it. Drove around, still was doing the same stuff.
    Took the lid off, RUNS PERFECTLY FINE. Its a whole new beast now.
    Only problem there is, around 1/4 to 3/4 throttle, just crusiing around, has a small hesitation. Push full throttle, takes a second, then takes off like a bad ass like it should.
    So with my thoughts, is getting too much fuel.
    I have NOT messed with the air/fuel screw yet. But I guess it might be off. Again this quad is compleltly stock with less than 20hrs.
    But, I believe ill be buying a HMF exhaust and Jet kit for it soon.
