'05 Motor Mounts Failed/Failing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Dec 22, 2008.
  1. Dec 11, 2011 at 11:07 AM
    #281
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Took a spin past the dealers lot yesterday and noticed my Tacoma was no longer parked in the lot. A peek through the windows in the bay doors revealed:
    I think the next 2 weeks are going to be interesting...
  2. Dec 11, 2011 at 11:33 AM
    #282
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    As a rule, I won't buy version 1.0 of a new generation vehicle, because this sort of thing happens all the time. Computer models are no substitute for real world conditions. Early adopters become the beta testers for engineers. The 6-speed manual is the same way .. Toyota quietly beefed up the syncros and shift forks starting in 07.
    Problem is we're not talking about a smartphone or computer that just needs a firmware flash. These are very expensive repairs & Toyota should be held accountable for such failures. Frankly I think every car should come with a mandatory 10 year / 100k mile warranty against engineering failures .. which this is. And if it happened to my truck, and Toyota refused to listen, I would howl about it to every consumer complaint site out there.
  3. Dec 12, 2011 at 8:06 AM
    #283
    caseymckeeborrego
    caseymckeeborrego Member
    desert hot springs
    06 prerunner
    K&N filter
    Looked under the truck, frame broken under the mount, will post pics asap.
  4. Dec 20, 2011 at 5:03 AM
    #284
    Fortech
    CANADA
    My truck was on the rack yesterday getting a wheel alignment, supposed to pick her up this morning.:cool:
  5. Dec 21, 2011 at 4:26 AM
    #285
    sar
    sar Well-Known Member
    Newfoundland, Canada
    2018 Tacoma TRD Sport DCSB Manual (on order)
    Glad you received the same level of satisfaction from Toyota that I did. A great Xmas gift for sure!
  6. Jan 1, 2012 at 8:03 PM
    #286
    Fortech
    CANADA
    Update:
    Still driving the Ford Supercrew. Still some issues with my truck that they have to sort out this week.
  7. Jan 13, 2012 at 4:40 PM
    #287
    Fortech
    CANADA
    Still driving the Ford Supercrew...
    Dealer had an issue with the ABS once the truck was reassembled on it's new frame, it seems the problems have been sorted.
    At the moment, the cruise doesn't work nor does the rear diff lock engage. Dealer has been great thus far on my behalf when dealing with Corporate. Its been a really big job with some complications.
    For anyone with a 2005 - 2006, purchase an engine mount reinforcement kit and get it installed regardless if you off road or not.
    The second easiest solution would be to reinforce the broken mount once it punches through. Same solution as above but now allot more complicated and expensive because the frame has already been punched through.
    The least desirable solution would be a frame swap, trust me...:(
  8. Jan 28, 2012 at 5:38 AM
    #288
    Fortech
    CANADA
    Got my Tacoma back from the dealer last Friday (January 20, 2012) with the new frame installed. During the first test drive I performed, I noticed the Rear locker wouldn't engage nor would the cruise control. I admit the dealer was very accommodating and replaced both the rear diff actuator as well as the spiral cable - now both the locker and cruise work as normal.
    Last weekend I spent allot of time underneath the truck in my FIL shop (had a lift :)) inspecting everything. A few wires had to be tucked away here and there, a marker light plugged in, and a few other small issues I took care of myself. New pads and rotors on the front were a must as well as a good caliper cleaning / lubrication. Inspected and adjusted the rear drums, etc.
    One issue I did find the hard way was the dealer neglected to attach the front diff breather line to the front diff - so after a 2 hour commute on the highway I arrived to find gear air spewed all over the front end. Not really a big deal I guess. Cleaned everything back up and installed the breather line.
    Overall I'm surprised how well everything turned out. Hopefully one year down the road I will be equally satisfied and no further issues arise from a total tear down of the truck. My maintenance will obviously have to be a little more detailed in the future, checking the torque on various fasteners and other components.
    The dealer estimated the total cost of the frame replacement including labor, parts, and a 124 day rental vehicle at approximately $24,00 - $25,000. I gave Toyota the option of a repair at a frame shop that would have set them back maybe $3,000 - $4,000 but it was denied. I don't understand why Toyota replace some frames under warranty and leave others out in the cold to fend for themselves. I suspect the local dealership has allot of influence in their decision.
    The end result...
  9. Jan 28, 2012 at 9:12 AM
    #289
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    Where can you get the reinforcement kit? Wondering what the cost is and to have it installed.
  10. Jan 28, 2012 at 10:12 AM
    #290
    Fortech
    CANADA
  11. Feb 29, 2012 at 6:16 PM
    #291
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Is that a crack above the new gussets that didn't get welded up? Last pic. btw...$250 is alot cheaper than what it would cost if that went un attended. That's a real world fab price, he has supplies to pay for and bills just like we all do. He didn't just weld stuff up, and upside down and in a tight area at that, he also made plates and gussets and dealt with that firey nightmare right above his head. I'm sure you just payed more than that for your cell phone and TV this month, and last month, and next month, and the one after that, and so on. What's that add up at the end of the year?
  12. May 8, 2012 at 4:07 PM
    #292
    midwayliberator
    midwayliberator Young and Learning Quick
    Colorado
    06 tacoma trd off road
    Icon UCA and Long travel coil overs, OME rear leafs. Currently on the build table is a Bed Rack and front bumper procomp 17 rims with 285 70 17 BFG. afe stage 2 cold air intake, magna-flow 2' pipe from cat back,
    So my driver side engine mount buckled into the frame. I called toyota dealers and corporate they wont do Jack! Something about a Trd off-road does not belong on anything except pavement. So my Question to all is should I pull the engine mount from the cavity, reinforce the frame then weld the mount back on? Or do what colvilletacoma with the right angle hold?
  13. May 8, 2012 at 7:01 PM
    #293
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    File complain with NHTSA its a safety issue, another complain with Attorney general and BBB. This is design flaw Ask Toyota to replay in writing. If you have to pay some attorney fees to write you up official letter to Toyota.
  14. May 8, 2012 at 9:19 PM
    #294
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.off-roadweb.com/tech/1107or_dmz_cure_fixing_broken_toyota_truck_motor_mounts/index.html
    There is a kit made for reinforcing these now. If it happens to me, I'd have the mount pulled out to where it belongs, welded as best as possible, then have this kit put in.
  15. May 8, 2012 at 9:24 PM
    #295
    joes06tacoma
    Joe
    Central Coast, CA
    I think ColvilleTacoma was being sarcastic when he said $250 was outrageous. Clearly it is probably the best deal on the planet for that kind of work in that kind of tight space. This is an old post, and I remember when he made it. I think he was just really happy to get his truck fixed at a price he could afford, at a time when everyone was still going "holy shit, how are we going to deal with this problem?"
  16. May 9, 2012 at 1:21 AM
    #296
    Fortech
    CANADA
    Get it back in place and weld it. Purchase the aforementioned kit and gusset the perch. Cheapest and best fix out there IMHO.
  17. May 9, 2012 at 2:20 AM
    #297
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    subscribed.
  18. Jun 11, 2012 at 9:00 PM
    #298
    blackbrit
    blackbrit Well-Known Member
    W. NC Mountains
    '05 DCSB 4x4 OR 6 Speed MT
    3 inch lift
    Thanks for all the details and updates. Subscribed, and checking mine.
  19. Jun 12, 2012 at 8:37 PM
    #299
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Wow. Now I'm paranoid. My whole desire to drive my truck "until the wheels fall off" may now change to "until the engine falls through." Is this something ALL '05 & '06 owners should fear? Is a weld-in frame brace kit a must?
  20. Jun 12, 2012 at 10:01 PM
    #300
    joes06tacoma
    Joe
    Central Coast, CA
    The 05-early 07 frames, as well as the 03-09 4Runners, and the 07-09ish FJ Cruiser all have the same weak design. The early 05 Tacomas also had a problem with the welds on the already weak design. The combination of the poorly engineered mount and the poor welds make the early production 05 the worst.
    I have seen posts from guys with 06 model Tacomas who have broken the mounts, I've also seen a few stories of 4Runners and FJs doing this. They all seem to be trucks that were railed on pretty hard.
    I feel like my 06 isn't going to be a problem unless I start to seriously wheel it. I don't plan on that, so I am doing nothing until there is an issue.
