'05 Motor Mounts Failed/Failing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Dec 22, 2008.
  1. Nov 25, 2014 at 8:16 AM
    #361
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I have a a NIB set of the DMZ motor mount gussets for sale. $75+ shipping
  2. Nov 25, 2014 at 10:17 AM
    #362
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    ^^^ Pmd you dude, ill take em but need shipped asap
  3. Nov 25, 2014 at 10:40 AM
    #363
    jeremyk61
    jeremyk61 Well-Known Member
    dumb question but how are the DMZ gussets installed? Just weld them on?
  4. Nov 25, 2014 at 10:29 PM
    #364
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Yup it's a weld on gussett.
    I layed 2-3 passes over the frame and mount last night should hold for now but def need the gussets to renforce the frame
    Fan shroud is pretty damaged and oil pan has a good dent in it too, not serious but will need replaced
  5. Nov 26, 2014 at 7:21 AM
    #365
    jeremyk61
    Looked at my mounts last night (I have a 156K miles on my 05) and they look fine. Should I leave as is, just run some new welds on top and along with the existing welds or add the gussets?
    And one more question about installing the DMZ fix, do you grind anything (i.e. what prep needs to be done) before welding the plates on or just clean and start welding?
  6. Nov 26, 2014 at 6:48 PM
    #366
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    If your wheelin it might be a good idea to gusset, if its just a road driver probably not likely ull need them but not a bad idea. Think the problem is hit or miss from what I've seen.
    I'd guess maybe a little grinding to the factory welds so the gusset fits true, ill have to anyways to welds i layed on but will see how thry fit
  7. Dec 22, 2014 at 2:41 PM
    #367
    Stevebis1
    Stevebis1 Member
    Steven
    Delmar, NY
    '05 Access Cab, 4wd, V6, 6 Sp. Man.
    I'm next... Daughter just drove 1000 miles back from College and told me "something is wrong with the motor, it sounds terrible" The noise is the fan fitting the plastic shroud as the engine has sunk about an inch.
    Just got the call back from the dealership and the mount will be covered under the frame recall.
    Parts are back ordered so they will be loaning a new 2015 Nissan Frontier until the work is complete. At the moment the expectation is that it will be more than a month.
  8. Dec 22, 2014 at 2:54 PM
    #368
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Never heard of this happening. Hopefully mine will be replaced with the frame recall
  9. Dec 22, 2014 at 2:55 PM
    #369
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Was this only a problem with 2005s?
  10. Dec 22, 2014 at 3:52 PM
    #370
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    You mean that didn't continue for the next 10 years? :lol: Yeah, they fixed the frame design by 2007.
  11. Dec 22, 2014 at 4:35 PM
    #371
    dakotasyota
    Dakota
    Ellensburg, WA
    Ruh oh. Maybe I should gusset when I have my diff pulled for regear...
  12. Dec 22, 2014 at 5:00 PM
    #372
    05Moose
    Jim
    Well, there was the weak tailgate fixed at some point. Most other issues like weak springs continue today. Really, the only issue on a 2005 or 2006 to address if you're worried about it would be the motor mounts. I've been off road a lot yet haven't had this problem. All other issues you just address "if" they come up.
  13. Dec 23, 2014 at 3:38 AM
    #373
    Stevebis1
    Stevebis1 Member
    Steven
    Delmar, NY
    I'll know more once the parts are ordered but the service manager thinks the replacement frames come with new springs.
    Last spring I bought a set of lightly used OEM replacements from a forum member that had his replaced under warranty but then raised his truck.
    Seems like a lot of pricey issues for a "bullet proof" Toyota...
  14. Dec 23, 2014 at 7:23 AM
    #374
    05Moose
    Jim
    Yes, new leafs. This is from another forum I'm on:
  15. Dec 23, 2014 at 7:53 AM
    #375
    dakotasyota
    Dakota
    Ellensburg, WA
    Oh I know... my tailgate is essentially bent it half. I'm just wondering if I should with the coming long travel... probably gonna make me run the truck harder over bumps :D
  16. Dec 28, 2014 at 11:09 PM
    #376
    bluesatyr
    bluesatyr Member
    Los Angeles
    06 Tacoma SR5 TRD
    Bone Stock
    I have an '06 Tacoma DBLC TRD Sport I bought new. I paid it off this year and, of course, things start happening. I'm not sure if this is a common symptom of the mount fail, but I have a noise that's been increasing in frequency/loosness in the suspension area of the left wheel. When driving on a moderately bumpy road, it clacks like to small pieces of loose metal bouncing off each other. or some kind of a bracket slapping against the frame. It does it when I stop and go. And more when I turn to the left than the right. It's been driving me nuts! I figured out that if I drive up onto a curb with my left front tire and compress the spring, I can rock the car back and forth laterally and it does it. clack clack. Or if I start the truck and turn it off. clack clack clack.
    I live in SoCal and there's no rust not the car at all. I also have a level EMU 2.5" lift with dakar leafs in the back and 881's in the front. I do have that common vibration on acceleration, but that may be because of the mount. The reason for the suspension upgrade was because one of the rear leaves broke, so I figured I give it a lift thinking it was something I had done... But I just got a letter about this from Toyota. They're determining how they're going to handle this issue of leaf springs breaking.
    So today, I climbed under there when compressed and finally determined that it must be the motor mount. I rocked the truck back and forth with my hand on the mount and it feels like that clack clack is inside the mount itself, but I'm not sure. Can't see it really clearly. But I'll look again tomorrow. I've brought it to three mechanics and a body shop, and no one can figure it out.
    Any input would be greatly appreciated. Did you have this sound?
    This sound started before my extended warranty ran out last year, but I had the tailgate replaced when I still had it. It bent in half when loading a motorcycle. But other than that, it's been a great truck! But it may be time to move on. This is a problem I don't trust at all. I've got kids and I want them to live long lives.
  17. Dec 29, 2014 at 6:09 AM
    #377
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The way you first described it it sounded like pwr steering rack loose or needing bushings..............
  18. Dec 29, 2014 at 7:20 AM
    #378
    jeremyk61
    sounds more like a ball joint to me or sway bar end links. I pierced the boots on all my ball joints and greased them and they quieted right down. I replaced the end links and even more noises went away.
  19. Dec 29, 2014 at 12:54 PM
    #379
    bluesatyr
    bluesatyr Member
    Los Angeles
    06 Tacoma SR5 TRD
    Bone Stock
    Thanks Jeremy,
    Yet another truck to add to the list. Just went to my local mechanic and we jacked the car up. There's a crack around the base of the mount. it just hasn't punched through yet. I called the Dealership where I bought the truck and waiting to hear back. Drag. Just bought new wheels and everything!
  20. Dec 29, 2014 at 1:49 PM
    #380
    05Moose
    Jim
    I'm curious to hear what happens since those back east can get the frame replaced under the rust frame recall. Since ours don't apply to that yet, it'll be interesting to hear if Toyota covers it the same.
