'05 Motor Mounts Failed/Failing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Dec 22, 2008.
  1. Feb 9, 2020 at 12:34 PM
    #441
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    To be repaired properly, the diff needs to be removed. Usually the driver side is the bigger issue so you may want to look at that a little closer. Anything that's cracked should be ground down and v notched and then re welded. Simply re welding isn't a final fix though. There's a reason Toyota added the additional mounting surfaces. The DMZ gusset kit is beautiful and adds all the additional support it needs. For someone experienced with doing the job it can still take 6 to 8 hours. The average guy with proper tools can knock it out in a weekend. It's a chore but it has been done by lots of people.
    Mine was down for a couple weeks to source the parts and get a good welder to glue it up for me.
  2. Feb 10, 2020 at 6:05 AM
    #442
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Removing the front diff is what I was hoping didn’t have to happen for a proper repair. I have a 97 Powerstroke that I have been putting a lot of work and effort into and I’m not looking to put much into the taco at 198k.
    After all the maintenance and care I put into the rest of the taco I’m pretty disappointed that the frame welds would be the catalyst for me to consider getting rid of it and moving on.
    This will be my last Toyota. Its true that the motors will go forever but the frames will fall apart.
    Definitely not interested in any Toyota made after 2016...
    05tacomabro[QUOTED] likes this.
  3. Feb 15, 2020 at 12:34 PM
    #443
    05tacomabro
    Alex
    Tucson
    It's really not that bad to remove the diff. After you pull the cv axles and the front driveshaft, it's really only a couple more bolts and a couple electrical connections. I removed my steering linkage as well, super easy. You could easily have it apart in a couple hours, spend an hour cleaning up the cracks, an hour welding it up and then re assembly. An extra hand certainly helps and the gusset kit goes on easy. Other than that, the only thing to really worry about on these frames it's the trans crossmember. Toyota changed that as well after 2007 I believe.
    whatstcp likes this.
  4. Feb 16, 2020 at 5:01 AM
    #444
    wyotaco06
    Offroad 4x4 06
    I’m pretty confident I could do the job of pulling the diff and fixing the weld, it’s more of a space and time problem for me. I don’t have a garage or shop so it would be done in the driveway and I have 3 plus feet of snow in my yard, driveway is all ice.
    Working full time doesn’t help with time. And my 1.5 yr old daughter gets lots of my time...
    My 97 Powerstroke is currently taking priority for projects of vehicular nature.
    Plan was to sell the taco but seeing as the weld hasn’t 100% failed yet I’m just gonna keep driving it. It seems like it has a ways to go before failure.
    It’ll be an in the future project, hopefully a long ways off!
    Thanks for your tips and insight
  5. Feb 25, 2020 at 10:46 AM
    #445
    ninja89
    ninja89 HUH?
    You should give dmz a call, Tim can answer all your question. And I’m curious too on the process
    05tacomabro likes this.
  6. Feb 25, 2020 at 12:53 PM
    #446
    05tacomabro
    Alex
    Tucson
    Tim is a great guy and answered all my questions. Definitely helped
    ninja89[QUOTED] likes this.
  7. May 23, 2020 at 6:41 PM
    #447
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Mine cost $500 to have fixed
  8. Sep 3, 2020 at 10:27 AM
    #448
    LexCorbett
    LexCorbett New Member
    Lex
    2006 Tacoma 4x4 Access
    Hey Guys,
    My 2006 gave me 245k KMs before the frame surrounding the driver side motor mount cracked... noticed when the rad fan started rubbing on the housing as several have before me..
    Can someone detail to me what is necessary to repair?
    What do I need to order? DMV Gusset Kit, a new motor mount, what else?
    Does the motor have to be pulled?
    Thanks,
    Lex
  9. Sep 3, 2020 at 10:38 AM
    #449
    Oreo Cat
    Mine was just pulled back into place and welded. No engine removal. Costed me $500
  10. Sep 3, 2020 at 10:39 AM
    #450
    Oreo Cat
    Mine also doesn’t have any gussets yet and is doing fine
  11. Sep 3, 2020 at 5:56 PM
    #451
    LexCorbett
    Lex
    Can you elaborate? I am likely going to do this myself and am curious as to what is the best strategy.
  12. Sep 3, 2020 at 8:48 PM
    #452
    Oreo Cat
    The guy who did mine got under it, took out the steering linkage, pulled the frame back into the spot it should be then welded the crack and left a massive bead over it
    LexCorbett[QUOTED] and whatstcp like this.
