'05 Motor Mounts Failed/Failing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Dec 22, 2008.
  1. Dec 26, 2008 at 5:19 PM
    #61
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As mentioned before, I have an 07 with a build date of 12/06 and I have the reinforcements.
  2. Dec 26, 2008 at 5:22 PM
    #62
    colvilletacoma
    colvilletacoma Well-Known Member
    Central Washington
    Toyota Tacoma
    OME 886 Coils, Bilstein 5100's in Front, Tuff Country in Rear, Custom Racks with winch built in
    oh whoops, totally forgot about yours.
  3. Dec 26, 2008 at 5:24 PM
    #63
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    My build date is 7/05, no reinforcements.
  4. Dec 28, 2008 at 8:37 PM
    #64
    pumasnack
    pumasnack Member
    Irvine, CA
    06' PreRunner Sport
    Mine was manufactured March 06' and I haven't looked yet, but I bet I don't have the reinforcements. Weekend project comin' up, time to break out the welder.
  5. Dec 28, 2008 at 8:44 PM
    #65
    Daddy_Rabbit99
    Daddy_Rabbit99 Active Member
    Thats what mine is also and no reinforcements. Very bad welds but no cracks could be seen. My dads 06's date us 9/05 and same no reinforcements.
  6. Dec 29, 2008 at 8:47 AM
    #66
    br217398
    br217398 Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    ive got an 4cyl....... 09/05 no reinforcement, but also the welds look like they should no bubbles, no gaps, looks like a strong weld on mine....
  7. Dec 29, 2008 at 9:00 AM
    #67
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I bought my '06 in October of '05. I'll crawl under tonight and see what I find.
    My front-end mods and reinforcements may have just increased considerably.
  8. Dec 29, 2008 at 4:57 PM
    #68
    colvilletacoma
    Central Washington
    Toyota Tacoma
    you should be ok with the 4cyl. There havent been any reported incidents with them. The size of the engine is also a factor as it is quite a bit lighter. But thanks for looking as I think you are the only who has replied with a 4cyl!
  9. Dec 29, 2008 at 8:43 PM
    #69
    br217398
    Orlando Florida
    you mean my engine sucks??? oh well i know....... Anything to help out :)
  10. Dec 30, 2008 at 4:27 AM
    #70
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I think my build date was June 06. Are the welded mounts the same on the 2.7 as the 4.0? If so I'll take a look at mine.
  11. Dec 30, 2008 at 5:20 AM
    #71
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure, but take a look and let us know. :)
  12. Dec 30, 2008 at 5:28 AM
    #72
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    I'm racking mine up this morning. Gonna check this out and let you know. But I have a double cab long bed. Still, I'm interested to see how they look. This was the LAST thing I'd expect from Toyota. :(
    I don't remember my build date but will post as well. Has anyone else looked at their long beds??
  13. Dec 30, 2008 at 5:38 AM
    #73
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Build date will be on the inside of the drive door jamb.
  14. Dec 30, 2008 at 10:06 AM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent heard of the frame separating, just the motormounts pushing into the frame/cracking. Do you have more info on the frame separating?
  15. Dec 30, 2008 at 10:57 AM
    #75
    pumasnack
    pumasnack Member
    Irvine, CA
    06' PreRunner Sport
    Checked mine, and the 06 DC V6 Prerunner Sport built 03/06 does not have reinforcements, however the welds are pretty thick and look to be rather stable. Mine is a Nummi too...
  16. Dec 30, 2008 at 1:18 PM
    #76
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    This guy has Frame Separation/Motor Mount issues on his FJC. Maybe it is the same guy timmer knows? He states that Toyota refuses to warranty it but Toyota R&D wants the frame for analysis so he's getting a frame swap for free. There's some good pics:
    Beginning:
    http://www.fjcruiserforums.com/forums/misc-technical-discussion/74262-i-broke-my-frame.html
    Same Thread, Post 109, Frame Removed with pic of Motor Mount: (new frame not reinforced)
    http://www.fjcruiserforums.com/foru...on/74262-i-broke-my-frame-11.html#post1219010
  17. Dec 30, 2008 at 5:46 PM
    #77
    colvilletacoma
    Central Washington
    Toyota Tacoma
    wow if all of us were so lucky.....
  18. Dec 30, 2008 at 5:54 PM
    #78
    colvilletacoma
    Central Washington
    Toyota Tacoma
    Also does anyone know if Dana makes the FJ's frame or if they are similar to the tacomas?
  19. Dec 30, 2008 at 6:09 PM
    #79
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. The FJ, Tacoma and Tundra are all made at the same plant. :)
  20. Dec 30, 2008 at 6:53 PM
    #80
    colvilletacoma
    Central Washington
    Toyota Tacoma
    alright good to know. I think im gonna have to sign up on the FJcruiser forum and try to get some papers from a certain someone.
