05 pre-runner Grease buildup on my pinion..normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Feb 16, 2010.
  1. Feb 16, 2010 at 8:42 PM
    bruce1271
    bruce1271 [OP] Well-Known Member
    Hey all, I was under the truck checking out my motor mounts and they look fine. But the pinion going in to the steering rack has thick dried grease on it from the rack all the way up to the u-joint. Any idea what this may be from? Are there grease fittings on the steering assembly? Will post a few pics tomorrow.
  2. Feb 17, 2010 at 6:49 AM
    bruce1271
    Ok, here is a pic of the pinion going into the steering rack. looks like something is/was leaking. You can see where I wiped some of the grease off(clean spot). Any ideas of the cause/fix? Is there a seal there? is that just plain grease? Feels like it. Doesnt seem like power steering fluid, unless its old and degraded.
    the 2nd pic is my steering pinion going up through my dash. Looks like that rubber seal fell down. Any tricks to making it stay put?
    Thanks!
  3. Feb 17, 2010 at 12:31 PM
    bruce1271
    Anyone got any ideas? Looks like it starts right at that ujoint and gets lighter as it goes towards the rack. Dont want to have any major issues if a simple re-lube can prevent it.
    Thanks
  4. Feb 17, 2010 at 12:55 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    could be grease from the u joint on the steering shaft,i think its normal.
  5. Feb 17, 2010 at 12:58 PM
    bruce1271
    Ok, thanks. I see all of the "motor mount failing" pics and everyones steering shafts look spotless. Mine is covered with grease. Thats my only concern.
  6. Feb 17, 2010 at 3:31 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Subscribed... Will keep and eye on this on my '09.
