05+ Prerunner to 4x4 Conversion
Discussion in 'Technical Chat' started by Khaos, Jun 15, 2008.
  1. Jun 15, 2008 at 12:34 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    We all know (or those of us who hang out on TTORA) know how easy it is to converte the pre 05 Tacos from PreRunner to 4x4.
    How hard would it be to convert a Prerunner 05 to a 4x4? I should think the hardest part is all the electronic garbage. Assuming I could find a suitable donor car, what would I be getting myself into if I attempted said conversion?
    Yes, I know it would be a pain in the ass, and I could easily trade in for a 4x4. I just dont want to.
    Edit:
    This conversion would not take place for quite some time. Maybe 2010 or 2011.
  2. Jun 15, 2008 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It really wouldnt be that hard. Instead of useing an electronic transfer case, just use a manual one. I havent looked into if one is made for the 05+'s, but it shouldnt be much different. I would try to keep everything divorced from the stock electronics in the truck if you can.
  3. Jun 15, 2008 at 6:35 PM
    Khaos
    Bryant
    A manual transfer case is almost something I prefer. But one of my goals of the (possible) conversion is to remain as stock looking as possible.
    If only Toyota had done it correctly the first time and gave us a manual transfer case...
  4. Jun 15, 2008 at 6:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    x2!!!!
    Thats why I like my Dodge (sorry) for the big off road stuff. Solid dana 60 axel, manual transfer case, 6 speed, and a Cummins. I know its too big for most trails, but I have a stratagy for that. It called "Force fit". :D
  5. Jun 15, 2008 at 7:38 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    have a dodge ram? If u do make ur taco a 4x4 u run the risk of causing problems then ur taco will never be the same
  6. Jun 15, 2008 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could you elaborate? I know of a few people that have converted their Prerunner to 4x4 with no ill effects.
  7. Jun 15, 2008 at 9:27 PM
    06BLUEDBLSPORT
    Colin
    Fort Wayne Indiana
    well you could mess up the electrical system if u use the electronic switch and you could run the rish of messing up you whole transmission or ruin the axle that your gonna install, i want to make my prerunner a 4x4 but its out of the question.
  8. Jun 15, 2008 at 9:34 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    those are risks you take anytime you mod any part of your truck
    if you get the proper parts/tools and have a half assed idea of what youre doing it'll turn out fine
  9. Jan 22, 2012 at 10:13 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Bump. Thinking of doing this.
  10. Jan 22, 2012 at 10:19 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    You will get a lot of:
    "it is not worth it, trade in and get a 4x4" and blablabla... So just :crapstorm:for it.
    In any case. Here is some things to put into your head.
    You will need the 4x4 transmission. The one from the prerunner will not fit with the transfer case from either the 4x4 Taco or the Manual from the FJ, which is what I personally want.
    If you do stay with your stock transmission, you can try and get a Transfer Divorcer, but last time I looked, there is only one company making one that fits and it is very expensive.
    All the electronics should be plug and play, but you need to get a new 4x4 computer and some other random electronics.
    I am not %100 on how the computer will react to it getting turned on manually vs with the button, but it is supposed to react as if it was factory if you have the correct wiring.
    This is apart from all the obvious front drivetrain changes.
    Anyhow, there are other threads here with more info and a part list, as well as threads on TTORA.
  11. Jan 22, 2012 at 10:23 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I wonder if you could use the computer electronics from an FJ to avoid this potential problem...most of the stuff from and FJ and Taco can be married if i'm not mistaken...
  12. Jan 22, 2012 at 10:26 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I plan to use all parts off a stock truck just like mine but 4x4, minus the transfer case. Then buy an fj transfer case. That way I don't have to deal with electronics. As for parts, the only thing I might need to find is the transfer case but I may have that covered too.
    Has this been done? Either switch or manual? If so is there a thread somewhere?
  13. Jan 22, 2012 at 10:27 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Already searched most of the threads on TW.
  14. Jan 22, 2012 at 10:28 PM
    I Liquid I
    Puerto Rico
    Someone did it in TTORA. But, they went double stick, so the "how to" will not help past a certain point.
    Also, not long ago, a member here changed his Electronic case for a manual one, but I think he also went double stick later on.
    You might want to look into what Colts suggested as well. Perhaps using the FJ 4x4 module would be much better than trying to do it with the Taco one.
  15. Jan 22, 2012 at 10:30 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea I don't need that. May attempt this soon so I'll see how it goes.
  16. Jan 22, 2012 at 10:32 PM
    Khaos
    Bryant
    I still want to do this. I still don't have the money. And I still will not sell my truck for a 4x4. After almost 70K together, as well as living in it for a few months, I'm quite fond of it.
    I'd much prefer using the manual t case of the FJ. I don't care for the push button or whatever the hell toyota calls it 4x4 system. Give me a lever.
    No way I'll be able to do this anytime soon. Another downside to having a small apartment...
  17. Jan 22, 2012 at 10:33 PM
    I Liquid I
    Puerto Rico
    It seems you are in the same boat as me. I also plan to do it, and do not need twin sticks or a crawler box.
    I do not currently have the time though, which is what has prevented me from attacking this.
  18. Jan 22, 2012 at 10:33 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I like how your post says maybe 2010 or 2011. Haha
  19. Jan 22, 2012 at 10:37 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    Man I wish i had the funds, time, and know-how on this. Ballpark estimate on the cost?
  20. Jan 22, 2012 at 10:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I'm aiming for $500-$1,500 for parts. Hopefully do the install myself.
