05 regular cab troubles
Discussion in '4 Cylinder' started by Corey08cummins, Jan 27, 2017.
  1. Jan 27, 2017 at 6:34 PM
    Corey08cummins
    Corey08cummins [OP] Member
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    Alright I bought this truck (05 regular cab 4x4 2.7l manual ) on January 13th that just so happened to be a Friday.
    I now have a CEL had it checked I don't remember # but something like coolant temperature below factory spec. The temp gauge on the instrument cluster doesn't work. Replaced thermostat didn't help. Has a very odd idle. When removed from any gear to come to a stop it jumps to around 2500 rpm down to 2000 rpm. Now it seems to have a horrible miss when driving between 1500 rpm to 2000 rpm but not noticeable at highway speeds. No CEL for the miss that I know of. Where do I start with this thing?
  2. Jan 28, 2017 at 7:13 AM
    tacoma4
    tacoma4 Well-Known Member
    Coolant temp sensor
    ecoterragaia likes this.
  3. Jan 28, 2017 at 7:29 AM
    Corey08cummins
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    Where is it located? Isn't there 2?
  4. Jan 28, 2017 at 8:02 AM
    tacoma4
    It's on the drivers side, kinda behind the manifold towards the back. You can check if it is working by measuring the resistance across the pins at different temps. At 68F it should be 2.3-2.6 kohms, at 175F it should be .3-.33 kohms. If it checks good, then you need to look for an open in the circuit.
  5. Jan 28, 2017 at 9:28 AM
    Corey08cummins
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    The code is P0128
  6. Jan 28, 2017 at 9:44 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That's coolant temp yes..
  7. Jan 28, 2017 at 9:46 AM
    ABA180
    East Bridgewater MA
    The 2004 FSM Diagnostics section lists 4 trouble areas for a PO128 code:
    - Thermostat
    - Cooling system
    - Engine cooling temperature sensor
    - ECM
  8. Jan 30, 2017 at 4:51 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Sounds like what others have mentioned. Faulty coolant temp sensor. On the 05 I'd recommend checking if the original water bypass pipe is still there. If so replace the plastic one with the correct metal version. You will have to drain the coolant as it is and trust me you don't want to pull the intake manifold off twice.
    Components I'd recommend replacing while in there.
    - Knock sensor
    - #2 Coolant water bypass pipe
    - #2 Coolant water bypass pipe gasket
    - Coolant Temperature sensor (rear engine block drivers side on cylinder 4)
    - Intake manifold gasket ( Felpro gasket is want I used and was identical to the OE)
    - Throttle body gasket (Felpro gasket was incorrect size. I used a Toyota gasket)
  9. Feb 16, 2017 at 9:54 AM
    Corey08cummins
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    Ok got the truck back from stealership. Engine coolant temperature sensor fixed but still seems to have a hesitation on acceleration. Has 4 new Denzo iridium plugs. & no CEL
  10. Feb 18, 2017 at 12:37 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Does it have a k&n air filter?
  11. Feb 18, 2017 at 3:38 PM
    2.7taco
    Texas
    I see where you are going good but a hard start issue won't be from the MAF. Mine had an over oiled K&N for years no problems. The only issue I had with it was the oils coated the IAT resistor and it was 35 degrees off all the time. Even still it started fine. If you disconnect the MAF on a second gen the engine dies.
  12. Feb 18, 2017 at 3:55 PM
    Corey08cummins
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    Hesitation finely turn to a full blown miss. Missfire #1 cylinder. Coil replaced
  13. Feb 18, 2017 at 3:57 PM
    2.7taco
    Texas
    How's the hot start?
  14. Feb 18, 2017 at 4:23 PM
    Corey08cummins
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    Every time today it didn't skip a beat fired right up
    2.7taco likes this.
  15. Feb 18, 2017 at 5:41 PM
    2.7taco
    Texas
    Keep an eye on everything for some time. Hopefully your fixed.
  16. Feb 18, 2017 at 6:56 PM
    Corey08cummins
    Corey
    Pounding Mill
    2016 DCSB 2012 RC
    I hope :fingerscrossed:
    2.7taco[QUOTED] likes this.
  17. Feb 19, 2017 at 12:10 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    After the repair it might have taken the computer time to re-adjust so the engine would run right. Usually, when I switch from 91 octane to 87 octane I disconnect the battery for an hour or so to let the computer adjust to the new octane. Recently I found 87 octane ethanol free where I live. I never disconnected the battery but after a couple of tanks the computer re-adjusted itself and this truck now runs as good as it did with 91 octane with the deathanol in it. I'll be running 91 octane deathanol free in the summer and 87 octane deathanol free in the winter from here on out. I have access to both but at different stations. Engines run so much better on deathanol free. Ethanol needs to be outlawed. It does nothing but negative things for the environment and ruins fuel mileage. My 2.7 loves the deathanol free. It seems to like the 87 octane even more than the 91 octane. I'll run the 91 again this summer and see if there is a difference. I may just end up running the 87 year around although I've been running 91 just about all the time since I bought it a couple of years ago. The 91 with the deathanol seemed to just make it run better but I could never put my finger on it. With 87 octane deathanol free I have noticed a big difference.
