05+ steering?
Discussion in 'Suspension' started by IRISHDEVIL, Sep 4, 2008.
  1. Sep 4, 2008 at 9:04 AM
    IRISHDEVIL
    IRISHDEVIL [OP] Well-Known Member
    If got an 07 db prerunner with a 3 inch lift and im having some steering issues that may not even be issues. Ive aligned the truck a few times and the same issue is still there. It seems to have alittle bump steer i think. Im not curtian but when i drive on a really bumpy surface the truck seems to go all over the place. Does anyone else have this problem if so what do i need to do to correct this. im sick of it. Ive heard that i need new uca's.
    Let me know if you guys have the same issue and if you have any ideas on how to fix it.
    thanks in advance
  2. Sep 4, 2008 at 9:08 AM
    Rockstar Junkie
    Rockstar Junkie Well-Known Member
    Springville,UT
    06 4x4 TRD Sport
    It seems like I have a little bump steer too. Not horribly bad, but there is something there. I have a 3" lift as well, with larger tires.
  3. Sep 4, 2008 at 9:12 AM
    IRISHDEVIL
    im running 285's with 5100 billys on OME 885's. I dont think the spring would cause this kinda of problem.
  4. Sep 4, 2008 at 9:27 AM
    BullKnob
    BullKnob Well-Known Member
    Utah
    08 Sport
    30' M/T Toyo Tires, 3" Tuff Country lift, Kenwood iPod adapter,Kenwood 7" sliding DvD player.
    3" lift same issue
  5. Sep 4, 2008 at 9:32 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    probably a castor issue.....which a set of total choas uca's will take care of. did you have the leaf spring tsb done??
  6. Sep 4, 2008 at 9:39 AM
    IRISHDEVIL
    dealer will not do it because i dont load the rear down enough and because of the lift
  7. Sep 4, 2008 at 9:43 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    What did you use for the rear lift?
  8. Sep 4, 2008 at 9:46 AM
    IRISHDEVIL
    I used 2 AAls. I cut the lowest one down 1 1/2 on both sides to give me a leaf pack as well as 5100 billy's
  9. Sep 4, 2008 at 9:46 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Yes Sir you got it. Mine does the same thing because of the stock usc's not being able to align quite right. Its only off by 1-2 degrees but it will make it wonder if the road is bumpy or rutted.
  10. Sep 4, 2008 at 9:49 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You won't need the TSB with the AAL, you arlready fixed the problem. Nice looking truck. I haven't experienced this problem and have a 3" lift with larger tires.
  11. Sep 4, 2008 at 3:40 PM
    IRISHDEVIL
    so the way it sounds is that im going to need some UCA's. who makes the best for the cheapest price?
  12. Sep 4, 2008 at 5:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like you have caster issues. Total Chaos UCA's will fix the wandering proble. Tacomas dont have alot of caster from the factory. I think only about 2.5 to 3.0* +/-. When I lifted my truck before the UCA's my caster was .7*, now with the TC UCA's installed, I have 2.5* and 3.0* driver and passenger side respectively. No more wander and bump steer is under control. Also, the TC UCA's give a bit more down travle to your front suspension, which is always a good thing. :)
  13. Sep 5, 2008 at 3:31 PM
    IRISHDEVIL
    Who has the TC UCA's the cheapest?
