05 Taco oil pressure sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeanL, May 18, 2020.
  1. May 18, 2020 at 10:53 AM
    SeanL
    SeanL [OP] New Member
    Sean
    2005 Tacoma 4.0 dblcab4x4
    Remanufactured engine
    I put a remanufactured engine in my truck. I put a external oil pressure gauge in so my oil pressure sensor is disconnected. I haven’t been able to locate a T fitting that would except both! Would this cause my check engine light to come on or cause other problems?
  2. May 18, 2020 at 3:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, as long as you have oil pressure you will be fine.
    The only thing that switch does is light an LED when the pressure is low.
    The truck don't care if you have it connected or not.
  3. May 18, 2020 at 3:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The sensor uses BSPT threads. Most aftermarket sensors use NPT. You may be able to find one with some savvy searching.
    I think that I found one, a while ago, or I purchased a BSPT adapter and tapped one of the holes to 1/8" NPT.
    Jimmyh likes this.
