05 tacoma 2.7l
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nayo4140, Jul 26, 2020.
  1. Jul 26, 2020 at 10:49 AM
    Nayo4140
    Nayo4140 [OP] New Member
    Nate
    Toyota tacoma
    Stock
    Hi everyone, im new to tacoma world and have some questions, my truck (05 tacoma 2.7l) is throwing the code p0304, cyl 4 missfire, i need some opinions on what it could be. I put new plugs, coil packs, and injectors in it. Did a compression check, all good, checked fuel pressure from tank, good. Im stumped and have no clue what else it could be. Thankyou in advanced.
  2. Jul 26, 2020 at 11:36 AM
    Hans_Gruber
    Hans_Gruber Well-Known Member
    Nick
    13 DCSB TX TRDOR 6MT
    All Stock
    Probably need to have it run on a diagnostic to make sure the PCM is properly sending signal to injector and coil. In the meantime swap coil and injector one at a time to a different cylinder to verify if the misfire stays on 4 or if it follows one of the components.
    Can you feel it missing or just the ecm throwing a code?
    Have you done any other work to the truck recently?
    How old are battery and alternator?
  3. Jul 26, 2020 at 1:06 PM
    Nayo4140
    Nate
    Toyota tacoma
    Stock
    Come to find out one of the new injectors were weak, replaced with a good old one and runs great now.
    TnShooter likes this.
  4. Jul 26, 2020 at 1:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What brand injectors did you use?
    Just curious?
    Thanks for the update.
  5. Jul 26, 2020 at 1:20 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome to the forum Nate :hattip:
