05 Tacoma 4.0 PO300 code.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slowoldman, Jun 30, 2023.
  1. Jun 30, 2023 at 7:56 PM
    Slowoldman
    Slowoldman [OP] Member
    North Carolina
    05 Toyota Tacoma 4WD SR5 DCLB
    No mods Yet, just purchased, keep an eye out for them. :)
    Hey folks, I did a search for this issue on here, but nothing directly related populated. My 2005 Tacoma with the 4.0liter engine when I start it cold, only the first start of the day it will run a little rough and sometimes log a PO300, but not all the time. Once it runs for 30:seconds no issues, I can drive it all day and start and restart it and it never acts up. I have ruled out plugs and coils. I have read some forums and they say head gasket. But I am not using coolant and it doesn’t smell like coolant when it runs rough. It’s just not bad enough to set a specific cylinder code yet. If anyone has had this issue specifically please let me know. I love this truck and have had it since 09. Thanks in advance for your help.
  2. Jun 30, 2023 at 8:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it’s not coolant, maybe a leaking injector?
    Have you checked the coolant in the radiator?
    The reservoir isn’t a good indicator.
  3. Jun 30, 2023 at 8:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The symptom sure sounds like a possible headgasket failing, the best check is to pull all the plugs and pressurize the cooling system with a pressure tester. Let it sit with pressure on it for a few hours and then look in each cylinder for coolant.
    IvanhoeTaco likes this.
  4. Jul 1, 2023 at 4:19 AM
    Slowoldman
    North Carolina
    I thought this as well. So when I was replacing my leaking valve cover gaskets and had the upper plenum off, I ordered what I thought was a “set” of injectors which what was it called it on Toyotas website for 138.00 I thought that’s worth it. Then parts arrived and it was 1 injector with seals on it. . I always referred to a set as ALL of something, but not Toyota. So, rather than guess which one it may be, I didn’t install it yet, as another 700 bucks to replace all of them for a guess is just not feasible at this time. Being I am not using coolant, and radiator is full, this was my thought as well. I’ll keep this thread updated once I figure this out. Thanks for the quick response. Have a Blessed weekend my friend.
    Dm93 likes this.
  5. Jul 1, 2023 at 4:29 AM
    Slowoldman
    North Carolina
    Good morning, I will do this, as it had crossed my mind, reason I have not yet is coolant system pressure is higher when running, so why wouldn’t it be worse or be using coolant then? I’m going to do this today and will update tomorrow. And thank you, for the helpful links you have on your response, I am considering buying a tool with a cylinder misfire graph, so I can watch it when I start the engine to determine which cylinder is acting up. But I’ll hold off unit the coolant system leak down test is performed. Have a Blessed weekend my friend!
    Dm93[QUOTED] likes this.
  6. Jul 1, 2023 at 7:10 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you checking the coolant level cold, before starting the engine? In both radiator and expansion tank?
    Dm93 likes this.
  7. Jul 1, 2023 at 9:10 AM
    Slowoldman
    North Carolina
    good afternoon, yes checking both when cold, as the level rises some in the expansion tank when it gets hot. Thanks again folks, can’t wait to update you with my findings!
    Dm93 likes this.
  8. Jul 1, 2023 at 9:23 AM
    Bishop84
    Bishop84 Well-Known Member
    Even with no visible coolant drop, it still is very likely a headgasket.
    The pressurized coolant mists into cylinders overnight and causes a misfire in the morning.
    You could try to get it roaring hot, park it. Then in the morning before starting it, remove each plug and inspect the cylinders for liquid.
    Traditional headgasket checks like the chemical don't work on these really slow leaks.
    SR-71A and Dm93 like this.
  9. Jul 2, 2023 at 6:14 AM
    Slowoldman
    North Carolina
    Update on my issue. I have confirmed it’s a head gasket unfortunately. Now, the questions for you good folks that helped determine the issue. My 05 Tacoma 4X4, quad cab, long bed has 230K. Do I fix it, or trade it in on a new one? I have the ability to fix it myself, just wondering your thoughts folks. I appreciate your time and feedback. Have a Blessed Sunday.
  10. Jul 2, 2023 at 7:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Even an older tacoma is still worth fixing in my opinion. Especially if you can do the work yourself
    New trucks are crazy expensive right now
    Larzzzz, BassAckwards, SR-71A and 2 others like this.
  11. Jul 4, 2023 at 4:35 AM
    Slowoldman
    North Carolina
    Tore the engine down yesterday afternoon. Man, that’s a lot of work. Glad there was a YouTube video with some important information given. Now, to clean up all parts up and generate an extensive parts list.
    zguy1 and Dm93 like this.
  12. Jul 4, 2023 at 6:07 AM
    salazam
    salazam Active Member
    It was blown between the cylinders, wasn't it?
    Don't forget to replace that stupid plastic water bypass tube with a metal one while you're in there.
  13. Jul 4, 2023 at 6:10 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    4.0L doesn't have that, that's on the 2.7L.
    salazam[QUOTED] likes this.
  14. Jul 27, 2023 at 4:16 AM
    Slowoldman
    North Carolina
    Just wanted to send a huge thank you for all the help getting my Taco sorted. I finished the head gasket repair and after a little hiccup it’s all good! I did invest in the factory service manuals, and I am so glad I did. They were Super helpful, and with the step by step instructions it kept me from overthinking and becoming overwhelmed. This repair looked a lot easier on the YouTube video for sure. But, after several nights and one long weekend, she is running like new. Now to get some new tires on her. Thanks again to all.
    zguy1, Bishop84, TnShooter and 3 others like this.
  15. Jul 27, 2023 at 5:02 AM
    zguy1
    zguy1 Well-Known Member
    Midwest
    I’m glad it worked out. I did mine last year and she is still running great.
  16. Jul 28, 2023 at 9:08 PM
    Foe
    Foe Active Member
    2006 Toyota Tacoma dbl cab extended bed 4.0
    Can you link the youtube video so I can watch it?
  17. Jul 29, 2023 at 12:54 PM
    Slowoldman
    North Carolina
