05 Tacoma 4 cyl secondary air injection system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IN 05 Tacoma, Sep 20, 2018.
  1. Sep 20, 2018 at 4:32 PM
    IN 05 Tacoma
    IN 05 Tacoma [OP] New Member
    2005 Maroon Tacoma 4cyl
    My 05 (101,000 miles) was making a whine on startup. Then after a couple of weeks the check engine lite came on. Local garage wanted $1300. to replace.
    I read on this forum about the system.
    I removed the pump - filter was gone, 40% impellers ground down, but I think pump still works.
    Local garage said valve was stuck open.
    I am trying to take off the valve, and see if I can clean and see if it still works.
    Slowed up by wrestling with a rusty nut - fortunately Taco not my prime transportation.
    I have several questions:
    1) if the valve and pump still work and I re-install (with new filter on outside of pump), will the 05 Taco go into limp mode?
    2) I read where at least one 05 Taco owner put a electrical bypass on. He posted back in 2016. My question is does it still work?
    3) is there some danger to driving with check engine lite on if pump/valve quit working?
    4) I see aftermarket pump and valves for sale - are they worth the money?
    anything I forgot to ask?
    Thanks.
  2. Oct 25, 2020 at 6:15 PM
    whitcher
    whitcher New Member
    2003bLandcruiser; 2008 tacoma 4X4
    none
    There is a ton of information on the SAS but not a lot of continuity. I can't see any posts about aftermarket air pumps. Reed valves seem to mostly be OEM. I don't see those offered aftermarket unless they are used. This seems to be a fairly complicated system and it can sometimes be difficult to troubleshoot.
    I was going to by a really nice 2008 2.7 Taco but after reading these posts I am reconsidering because I just got whacked with the dreaded p0442 evap code on my Landcruiser! One thing at a time please. There is truth that car electronics saved the ICE, but they simply don't age well. Might be time to buy a "new" car, meaning one that is 2-5 years old instead of 15-20years old , like everything in my fleet!
