05 Tacoma 4x4, Charge Light on but Alternator is Charging Fine
Discussion in 'Technical Chat' started by cgrossl, Aug 29, 2014.
  1. Aug 29, 2014 at 12:04 PM
    cgrossl
    cgrossl [OP] Member
    Cameron
    Lexington, KY
    05 Tacoma 4x4
    Hello,
    I recently inherited an 05 Tacoma regular cab, 4x4, 2.7 off of my late father in law. The truck is a little rough, but after looking at it a little closer, its not too bad. A paint job and some basic maintenance should make it into a nice truck.
    Anyway, the charge light is on. Usually, this indicates that the charging system is either not charging at all, or over charging. But, on my truck, I get 13.7-13.8 volts all day long, no matter what kind of electrical load. Its the same at idle and cruise RPM. According to my volt meter, the charging system is doing its job. So, why would the charge light be on? Any electrical gurus out there?
    Thanks,
    Cameron
  2. Aug 29, 2014 at 12:19 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Bad body ground. Strart simple when it comes to electronics.
  3. Aug 29, 2014 at 2:22 PM
    cgrossl
    cgrossl [OP] Member
    Cameron
    Lexington, KY
    05 Tacoma 4x4
    Good idea. It's easy to over complicate this stuff sometimes.
  4. Aug 30, 2014 at 11:27 AM
    cgrossl
    cgrossl [OP] Member
    Cameron
    Lexington, KY
    05 Tacoma 4x4
    I cleaned all of the body grounds that I could find. No change. Any ideas?
