05 Tacoma A/C intermittent issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KW7777, Sep 13, 2014.
  1. Sep 13, 2014 at 6:50 AM
    KW7777
    KW7777 [OP] New Member
    Southeast
    05 Prerunner
    When turning on A/C the unit will sometimes not start on any speed. After a few minutes A/C will start and work with no issues. Very inconsistent....can go a week with no problem and then may occur multiple times in a day??
    I installed a new resistor and connector as mine had the tell tale "brown streak on the gray connector.
    I am out of tricks......any suggestions?
  2. Sep 13, 2014 at 7:18 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I'm thinking your next component failure to check or replace may be the blower motor. Keep in mind that the resistor is where the fan gets its speeds, otherwise the motor is just a plain old 2 wire motor that if defective, doesn't care what speed your on, it's not going to do it. I will also suggest that you wiggle the connector on the resistor during one of the times that it will not start. Maybe one of those V shaped pins is not catching the resistor pin as it does after it got loose and got hot. It should not be an issue, but that is a quick/cheap troubleshooting test.
  3. Sep 13, 2014 at 7:33 AM
    KW7777
    Southeast
    05 Prerunner
    Thanks...hoping its not blower motor.
