05 Tacoma a/c not blowing cold air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerimiahcontreras, Sep 11, 2016.
  1. Sep 11, 2016 at 10:12 AM
    jerimiahcontreras
    jerimiahcontreras [OP] Well-Known Member
    jerimiah
    2005 black tacoma
    my a/c on my 05 Tacoma (190,000) miles is not blowing cold air.
    My a/c blows air but it's just not blowing cold air, the compresser clutch is working fine, everything is rotating as it should. Also the blower motor is fine.
    Only things I can notice is that it's not blowing cold air and there is a hissing noise behind my dash.
  2. Sep 11, 2016 at 10:22 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    There is a rubber drain hose that sticks out of the firewall under the hood on the passenger side. Make sure that hose is not clogged. It may be plugged and filled your air box with water
  3. Sep 11, 2016 at 10:39 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    sounds like a line may be leaking or disconnected
  4. Sep 11, 2016 at 10:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Take it to a professional.
    Seriously. Your description indicates minimal AC system knowledge. Which is fine. But it also means that to fix it right, you need help. More than is available over the internet. At a minimum specialty tools.
    Find a good shop in your area with a long term reputation for honesty, AC skills and fair prices. That alone could be a lot of work, but it will pay off in the long haul for you, especially on a high mile vehicle.
  5. Sep 11, 2016 at 10:53 AM
    jerimiahcontreras
    jerimiah
    2005 black tacoma
    i checked the rubber hoes from what i can see it isn't plugged.
  6. Sep 11, 2016 at 10:53 AM
    jerimiahcontreras
    jerimiah
    2005 black tacoma
    i would take it to a pro but i am on a budget.
  7. Sep 11, 2016 at 11:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    The drain being plugged would not create a no cold air situation.
    It might cause a slosh or gurgle, but not a hiss. It would also overflow in cab and soak passenger side carpet.
    The hiss may well be a refridgerent leak. If it is it will end when the refridgerent is gone.
    If underdash, that means either a bad expansion valve or evaporator. Dash removal required.
    Additionally, a new accumulator will be needed, an evacuation of the repaired system, an oil and refrigerant charge. Misc. o rings a full set of pressure gauges and a vacuum pump at a minimum of specialty tools.
    Good news though. This is the internet. I'm guessing based on your description, so could be a wrong diagnosis.
    And winter is coming.
    So, save your $ (your budget has an emergency fund, right?) and take it to a pro before spring.
    Jimmyh likes this.
