05 Tacoma, crank no start -SOLVED-
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dvrich, Jun 8, 2023.
  1. Jun 10, 2023 at 1:42 PM
    #161
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It sounds like the PCM is coming and going if the CEL isn't staying on.
  2. Jun 10, 2023 at 1:43 PM
    #162
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The A/T temp, Oil and Check Engine lights should stay on with key in run.
    I just confirmed it.
  3. Jun 10, 2023 at 1:44 PM
    #163
    TnShooter
    Deogee
    STOCK
    So, we fooled with the IGN fuse and miraculously had communication to the ECM and power to the EFI fuse. And now we don’t?
    Maybe fool with that fuse again:rofl:
  4. Jun 10, 2023 at 1:45 PM
    #164
    Dvrich
    Dvrich [OP] Well-Known Member
    Rich
    2005 black tacoma
    If I can get my scanner to pick up the ECM I do
  5. Jun 10, 2023 at 1:46 PM
    #165
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea I'm wondering the same thing, do we have intermittent power or ground the the PCM, is the PCM flaky, or is something else going on.
    TnShooter[QUOTED] likes this.
  6. Jun 10, 2023 at 1:48 PM
    #166
    Dvrich
    Rich
    2005 black tacoma
    I can't get the scanner to detect the ECM all of a sudden. That's not good
  7. Jun 10, 2023 at 1:49 PM
    #167
    Dvrich
    Rich
    2005 black tacoma
    I tried that. Removed good fuse and put old one back in. Lost power. Something is wrong with that old fuse for sure
  8. Jun 10, 2023 at 1:49 PM
    #168
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea something isn't right, is your battery voltage still good?
  9. Jun 10, 2023 at 1:51 PM
    #169
    Dvrich
    Rich
    2005 black tacoma
    Still have power coming out of connector 1f on pin 13 so power is getting through fuse block to ecm
  10. Jun 10, 2023 at 1:54 PM
    #170
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I meant is your battery not weak (under 12v)?
    Have you checked power at E8 Pins 1 and 2 (Black) since we resolved the first problem?
  11. Jun 10, 2023 at 1:57 PM
    #171
    TnShooter
    Deogee
    STOCK
    I’m still catching up.
    See if this sounds correct.
    1. We had no power orange wire pin 9 of E8
    2. No power to EFI 2 fuse.
    3. Changed IGN fuse and got power to orange wire and EFI fuse.
    If so, it looks IGN power at the ECU controls the EFI command.
    Maybe keep the key on and test light on the EFI No2 fuse. Start wiggling wires and fuses, Once you see the EFI No2 fuse light up, you found a problem.
    I mean, I’m pretty lost as of now. I’ll keep thinking on it.
  12. Jun 10, 2023 at 1:57 PM
    #172
    Dvrich
    Rich
    2005 black tacoma
    Should those have power? Because with key on I have no power at those pins
  13. Jun 10, 2023 at 1:58 PM
    #173
    TnShooter
    Deogee
    STOCK
    Yes they should.
    And the EFI No2 fuse will have power too.
  14. Jun 10, 2023 at 2:01 PM
    #174
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes they should have power with the key on, they are fed by the EFI relay so if you have power at the EFI No 2 fuse but not at those terminals we are looking for a broken/corroded wire.
    TnShooter likes this.
  15. Jun 10, 2023 at 2:02 PM
    #175
    Dvrich
    Rich
    2005 black tacoma
    Ok I have power at them now. It seems wierd. But maybe I just suck at pinning them and didn't hit the connection the first time
  16. Jun 10, 2023 at 2:03 PM
    #176
    TnShooter
    Deogee
    STOCK
    So, we need to confirm
    1. Power at EFI No2 - Yes or No
    If yes, maybe move to connectors 1B and 1H?
  17. Jun 10, 2023 at 2:04 PM
    #177
    TnShooter
    Deogee
    STOCK
    Check E8 pin 9
  18. Jun 10, 2023 at 2:04 PM
    #178
    Dvrich
    Rich
    2005 black tacoma
    My battery is not holding a charge. Maybe low juice is causing issues?
  19. Jun 10, 2023 at 2:04 PM
    #179
    Dvrich
    Rich
    2005 black tacoma
    Pin 9 has power too.
  20. Jun 10, 2023 at 2:05 PM
    #180
    TnShooter
    Deogee
    STOCK
    It needs power with key On
    Was the key on?
