05 Tacoma engine mount weird sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drabbit17, Jun 17, 2012.
  1. Jun 17, 2012 at 5:04 PM
    Drabbit17
    Drabbit17 [OP] Active Member
    Diego
    Costa rica
    05 sr5 access cab
    Hello All, I've read some posts about engine mount problems in 05 and 06 tacomas. I think Im having that kind of problem with my truck .. it makes a weird sound when I change the gear from N to R. So I check it yesterday and it seams that the problem is located there. I just dont know if its the engine mount or the welds. The welds look fine for me but its kind of hard to check it right.
    I just dont know if some of the other guys that have a tacoma had the same weir sound and that;s how they discovered that it was the mount or the welds.
    Also if someone knows the part number of that engine mount so I can have it in case I need to change it.
    Hope someone can help me.
  2. Jun 17, 2012 at 7:18 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Is your foot hard on the brake pedal when this happens?
  3. Jun 17, 2012 at 7:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check your driveshaft center bearing for excessive play as well while you're under there. [​IMG]
  4. Jun 18, 2012 at 7:10 AM
    Drabbit17
    Diego
    Costa rica
    05 sr5 access cab
    I'll check this and I'll let u know.. tks for the post
  5. Jun 18, 2012 at 7:10 AM
    Drabbit17
    Diego
    Costa rica
    05 sr5 access cab
    Not really.. or well I dont feel it.
  6. Jun 18, 2012 at 9:23 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    What kind of sound ? Could be your brake pads, they move around when low and make a click or rattle sound. Could also be a bad u-joint.
  7. Jun 19, 2012 at 8:49 AM
    Drabbit17
    Diego
    Costa rica
    05 sr5 access cab
    Here is an update of the weird sound. It can't be the pads cause the sound happens even if the car is not moving. It happens when the car is moving and theres a lot of bumps in the street and also if im parked and I have the hand break push and I change the gear between N and R. If I change it between N and D nothing happens. What I think is that when I change the gear the engine moves and that what is causing the sound.
    If I push the engine a lil bit, or if I put some weight in the engine and change the gear does not make any sound. So thats why I think is the engine mount. Im going to take it out to see if there's something wrong with it or with the welds..
    I'll keep you posted..
