05 tacoma overheating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris165060, Aug 5, 2022.
  1. Aug 5, 2022 at 4:13 PM
    Chris165060
    Chris165060 [OP] New Member
    05 tacoma trd
    Hello, I just recently bought a 05 tacoma trd sport with 230km on it. Everything was great until I tried to tow my 3500 lb camper and began to overheat. I immediately turned the vehicle off and quit towing. Flushed the rad with water and a prestone rad flush and everything was good again until I towed and began to overheat again. Just recently got my thermostat changed and everything is fine but two days later now my
    Rad is low and overflow is already empty. Never notice and leaks under the vehicle, no smoke from exhaust, no coolant smells, no codes. Any ideas? I also have noticed my lower rad hose does not get very warm.
  2. Aug 5, 2022 at 4:25 PM
    jozy_s13
    jozy_s13 Member
    Jozy
    2006 Taco
    Do a block test, and check your oil on the dipstick, your radiator might just need some cleaning too from the outside
    Key-Rei likes this.
  3. Aug 5, 2022 at 5:37 PM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    You may, probably, have a blown head gasket.
  4. Aug 5, 2022 at 5:45 PM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Sounds like a head gasket...do a combustion test on the radiator..Napa sells the kit as well as other places..About 30 bucks..
  5. Aug 5, 2022 at 5:48 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    If the coolant is low it had to go somewhere. If its not on the ground the head gasket is probably being steam cleaned with it... Hopefully it is not though...
  6. Aug 5, 2022 at 6:12 PM
    Waasheem
    Waasheem
    2007 xrunner
    It's possible you didn't get all air out of the cooling system when you worked on it, easy to happen. Top it off again, see what happens.
    You could do the block test, just for peace of mind. You could probably rent one if you don't own one.
    Geeves77 likes this.
  7. Apr 13, 2023 at 9:08 AM
    jozy_s13
    jozy_s13 Member
    Jozy
    2006 Taco
    Pull the radiator and water the fins down you could have mud stick up in there, mine did
  8. Apr 13, 2023 at 10:40 AM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    What engine? I don't know if TRDs are only available with the V6.
  9. Apr 13, 2023 at 10:50 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    How’s the reservoir look? Any water noises in the dash?
