05 Tacoma Shakes, Pulls right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cmangum3, Jan 20, 2021.
  1. Jan 20, 2021 at 9:11 AM
    cmangum3
    cmangum3 [OP] New Member
    Christopher
    Fort Mill
    2005 Black Tacoma V6 4x4 Double Cab
    After market wheel, 18 inch Nerf bars LED lights
    Hey all,
    I just recently bought a 2005 Tacoma, Double Cab, 4x4 V6, 118k miles on it, no rust, town driven by the previous owner. Great shape, 4 wheel drive runs smooth.
    Once I bought it, I bought new tires for it, Uniroyal Tiger Paws (a decent midrange general purpose tire.) I put new tie rod ends and sway bar end links on it. I aligned the truck, (I'm an alignment technician so I did all of this work myself at my place of work). Before I bought it, the previous owner also had a Toyota dealership install brand new OE leaf springs. The shocks and struts are fairly new as well.
    Anyways, the truck shakes at speeds of 55-65 mph, in the steering wheel especially. A little can be felt in the seat. Once I get to 70-80 mph or so, it smooths out pretty nicely. I've balanced the tires again, on a different balancing machine. Still nothing. I don't know if this may contribute to the problem but the previous owner also installed 18" after market wheels. Maybe the wheels are bad? None of them are bent or beat up.
    I've also got a pull problem. No matter the speed, no matter the crown of the road, it pulls right. I have to keep the steering wheel slightly canted left to keep it straight. I've aligned it three times and it changes nothing.
    And lastly, I feel the steering is a little loose at highway speeds. I don't know if that's just a standard thing for older toyota trucks or if it could be a fixable thing.
    Anyways, I'd appreciate any and all feedback. I love the truck either way, just hoping I can tune it a little finer and smooth out some discomfort.
    Appreciate it guys.
  2. Jan 20, 2021 at 9:46 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Sounds like your tires need to be rebalanced. I would have he tires rotated on the wheel and balance again. Also what kind of lug nuts are being used on the wheels? If the wheels are not hub centric, lug centric lugs should be used. 18 inch wheel are notorious for wandering. I recommend getting a new set of 16 or 17inch wheel and tires. But that's just my opinion.
  3. Jan 20, 2021 at 10:00 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    last time I had something like that, it was the barring
    cmangum3[OP] likes this.
  4. Jan 20, 2021 at 10:06 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Check the drivers side cv axle for excessive play where it goes into the diff. If it has alot more play than the right side then you probably need to do the ECGS bushing replacement. Lots of info here about doing the job. The aftermarket wheels could also be the problem.
  5. Jan 20, 2021 at 10:12 AM
    cmangum3
    Christopher
    Fort Mill
    Gotcha, so you think like to front hub bearings maybe?
  6. Jan 20, 2021 at 10:15 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    May/may not be relevant. I had a Saab 9-3. Many of them would develop such a shake at a specific speed range (almost exactly as you're experiencing). Many tried constant rebalancing (even finding shops with the Hunter RoadForce machine) to no avail.
    The problem was a bushing in the case where the CV axle inserted into the case. The bushing would get worn/wallow out over time, and allow excessive play of the CV shaft at the case.
  7. Jan 20, 2021 at 10:19 AM
    cmangum3
    Christopher
    Fort Mill
    Gotcha, yeah the shop I work at has a standard balancer and a Hunter road force, both I'm proficient at using and use on a daily basis. I'll have to check that out. Appreciate it!
  8. Jan 20, 2021 at 10:24 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    you sure nothing is bent? spindles, control arms?
  9. Jan 20, 2021 at 11:19 AM
    cmangum3
    Christopher
    Fort Mill
    I'm pretty sure everything is straight. Nothing weird or looking damaged.
    A friend suggested a measure the rear axle and how far the center of each hub is off the truck fender and what I found was that the left hub is pushed 1/2" - 3/4" forward more than the right side which would make sense why the truck would push right wouldn't it?
  10. Jan 20, 2021 at 12:33 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    If the rear left side is sitting more forward than the right it would possibly cause the truck to turn left as well (think of steering a wagon backwards) and the steering wheel correction would be to turn right. Have a friend follow you to see if you're travelling down the road crooked (crabbing). Is there any history of accidents?
    Cheers
  11. Jan 20, 2021 at 3:09 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Have you balanced using the road force
  12. Jan 21, 2021 at 1:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the wheels are not Hub Centric you may need some hub rings. The center hole should be 106 mm for the Tacoma. If it is larger than that yiu need hub adapter rings.
