05+ Tacoma skid plates GB/Sale 3/15-4/15
Discussion in 'Relentless Fabrication' started by RelentlessFab, Mar 15, 2012.
  1. Mar 19, 2012 at 7:56 AM
    #141
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    one more...
  2. Mar 19, 2012 at 8:03 AM
    #142
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
  3. Mar 19, 2012 at 8:53 AM
    #143
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    No sir, just drilled out and then a 1/2" Grade-8 bolt secures the skid through them with a nut up inside the frame rail.
    I'll Add you into the main list. :thumbsup:
  4. Mar 19, 2012 at 9:01 AM
    #144
    RelentlessFab
    Eric
    Sparks, NV
    2 more for 21+ discount on the IFS; 1 person signed up for skids is the winner from the giveaway.
    All totals are updated now.
  5. Mar 19, 2012 at 9:04 AM
    #145
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    hey relentless, i sent you a pm about a bumper can you get back with me about it im really leaning toward buying one by May
  6. Mar 19, 2012 at 9:26 AM
    #146
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Hi Eric, great job on the skids (I wish I had more money right now). I had a question about the T-Case Skid, and how it mounts to the Mid Skid. I see the Mid Mount bolts to the cross-member, and I see the rear bolt mounts for the T-Case skid, but how do the 2 connect to each-other? How easy are they to separate if needed?
  7. Mar 19, 2012 at 9:43 AM
    #147
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    money sent :woot:
  8. Mar 19, 2012 at 9:52 AM
    #148
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    Also looking to see what the answer is here. It looks like the T-case skid is simply resting on the mid skid.
  9. Mar 19, 2012 at 10:45 AM
    #149
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Looks to me like it mounts using the same hardware... Through both the tcase and mid skids and into the cross member.
  10. Mar 19, 2012 at 10:48 AM
    #150
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    That was my initial thought as well, but it seems like it would be a PITA to reach those bolts without a 10" extension and elbow joint.
  11. Mar 19, 2012 at 11:00 AM
    #151
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Eric, I sent you a PM for a quote on a complete set, standard thickness, Id like to be on the list for the first round please.
    Thanks
  12. Mar 19, 2012 at 11:10 AM
    #152
    TrdSurgie
    TrdSurgie revised
    Oahu
    Gahhh I want the mid skid in aluminum also. please add it to the list.
    Oh and hurry with your paypal information so I can pay and not be able to change my mind on adding the mid skid!!:p My wife is gonna kill me. ha
  13. Mar 19, 2012 at 2:06 PM
    #153
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Gear wrenches FTW! Took me like 15 minutes to mount it up by myself, excluding drilling the two holes, course I'd had it on and off a few times. Obviously start with a pilot hole and slowly work your way up as you're going through two pieces of c-channel frame.
    They mount with bolts that run from the cross member through the mid skid and then if you get the t-case skid they go through that and it sandwiches everything together. 4 bolts total. Remember, it's clamping force that keeps things together, not typically the shear strength of a bolt.
  14. Mar 19, 2012 at 4:41 PM
    #154
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Nice, thanks for clarifying. I didn't know how much clearance there would on the top/sides, plus I have fat arms and meatinitis digitarus (sausage fingers). Thanks again man.
  15. Mar 19, 2012 at 4:57 PM
    #155
    Tat2dTaco
    Tat2dTaco He who breaks things.
    Ricker
    San Antonio, TX
    05 SWB Prerunner
    Camburg Spindles All-Pro Expo Leafs Bilstein 5100s and 7100s DTF Pre-Runner Bumper Tons of other crap
    I'm in for IFS and Mid Skids :D
  16. Mar 19, 2012 at 6:40 PM
    #156
    RelentlessFab
    Eric
    Sparks, NV
    Replied
    Yes, and longer bolts are required(and included) to go through the cross member and all the skids. Its a tight fit to access, but can be done.
    Replied
    Thanks for filling them in Max. :)
    Will add you to the list!
  17. Mar 19, 2012 at 6:41 PM
    #157
    PLC721
    Patrick
    Chandler, Az
    Eric did you receive my payment?
  18. Mar 19, 2012 at 6:42 PM
    #158
    RelentlessFab
    Eric
    Sparks, NV
    Yep, thanks!
  19. Mar 19, 2012 at 6:46 PM
    #159
    PLC721
    Patrick
    Chandler, Az
  20. Mar 19, 2012 at 7:51 PM
    #160
    TrdSurgie
    TrdSurgie revised
    Oahu
    Eric, please add aluminum mid skid to my IFS order. Would it be possible to cut Relentless into the front of the IFS instead of just the "R"?
    I also need information to send you the mulla.
    Thanks!
