05 tacoma speedomoter
Discussion in '4 Cylinder' started by jimmyjoe, Dec 22, 2010.
  1. Dec 22, 2010 at 9:47 PM
    jimmyjoe
    jimmyjoe [OP] New Member
    05 tacoma 4 banger 5 speed
    Hello, today my 05 tacoma 4 cyl 5 speed truck's speedomoter stopped working completely. the odometer and tach work just fine. i cant find any burned out fuses. it has 69 k miles on it. can anyone advise my on what else i can check?
  2. Dec 23, 2010 at 8:17 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    If only the speedometer stopped working you most likely need to replace the entire instrument cluster. If it was a fuse the entire cluster would not work, not just the speedo part. The fact that the odometer works tells me your speed sensor is working ok, so you can rule that out as a possible problem. This sucks because the cluster is pretty expensive:mad:. You may also see about finding an electronics shop that can repair it for you.
