05 tacoma stiff automatic gear shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jamie R. Cherry, Apr 21, 2011.
  1. Apr 27, 2013 at 3:38 PM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Color-matched Leer cap
    How'd it go? What'd they determine?
    -- Tim --
  2. Apr 29, 2013 at 5:44 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Interested in this thread myself. My 2005 suffers the same problem...
  3. May 21, 2013 at 9:41 AM
    Fortech
    CANADA
    Still suffering...
  4. Jul 16, 2013 at 5:20 PM
    Drywaller
    Drywaller Member
    anyone have a fix for this yet?Mines doing the same thing ,Ill keep looking
  5. Jan 28, 2014 at 10:55 AM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Mine went through an odd respite this fall - didn't do it for a long time. Winter set in, and it started again. Winter got cold and I got sick and the truck sat for a while... and when I tried it again (after nearly a month), it wasn't too bad. I'll bet come spring it'll get really bad again, though - it seems to get worse in wet weather.
    -- Tim --
  6. Jan 28, 2014 at 11:20 AM
    Drywaller
    Drywaller Member
    Toyota replaced my frame a couple months ago, So I had them replace my shifter cable thinking it was that.I brought it home and it sat a few days and was stiff as hell again
    So it took them few more days to figure out it was a prndl switch.works like new now and had since the switch replacement.
  7. Jan 28, 2014 at 11:51 AM
    gearcruncher
    Canadain bumper technician
    Should be easy to diagnose next time it happens . Take the shifter cable off the transmission and grab the transmission shift lever at the prndl switch and move it back and forth with your hand while you are under the truck . The shift lever should move with your hand fairly easy ,click , click , click is what you will hear while you are moving the shift lever through the detents ,if it doesnt move by hand , rust /ice moisture building up behind the seal . Take a small screwdriver and pry the seal open enough to blast some lube behind the transmission lever seal . At the same time , sit in the truck and try moving the gear shift from park to low to eliminate the shifter cable .The shifter should feel like there is nothing there because the cable is disconnected from the transmission
    If you are under the truck , make sure the wheels are blocked
    I am assuming not all of you are having the same issue . I have seen the shifter cable melt when people do not re-install ground straps on their vehicle . Check your ground straps
    Also check cable alignment when body lift is installed . The cable can bind if its not re-adjusted when a lift is installed
    Jon G and MTopp like this.
  8. Jan 29, 2014 at 7:46 AM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    EXCELLENT diagnostic steps, GearCruncher.
    -- Tim --
  9. Jan 29, 2014 at 9:03 AM
    gearcruncher
    Thanks Tim .
    Ive done hundreds of shifter cable problems .
    I will even take it one step further .
    To properly adjust shifter cable , put transmission in park and "REMOVE THE Ignition KEY " Just throw it on the seat until youve made the adjustment
    Go under truck with wheels blocked ofcourse and remove the cable from from the transmission lever .
    Grab the shift lever by hand and move it to the park position .
    Go to the back of the truck and verify you cant push the truck by hand so you know the cable is in park as well as the transmission .
    Now that you know the transmission is in park and the shifter is in park , adjust the cable until it fits into the hole on the shift lever .
    Verify the truck will only start in park and nuetral .
    The Key to proper adjustment is removing the Key:D
  10. Jan 29, 2014 at 9:18 AM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  11. Jan 30, 2014 at 6:35 AM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    GearCruncher... you can actually pry the prndl switch seal away enough to shoot lube into it? THAT'd help! What's a good lube? Would it be reasonable to squirt Marvel oil in with a squirt can? That might just be what it takes for these dang things.
  12. Feb 6, 2014 at 6:25 PM
    gearcruncher
  13. Mar 2, 2014 at 10:07 AM
    124360.Bergy
    124360.Bergy New Member
    2005 tacoma
    In response to this trouble I found on my Tacoma that the problem was a rusty neutral safety switch which is located on the passenger side on the vehicle. You can open your hood and see it on the transmission on the passenger side behind opposite the oxygen sensor. To fix get yourself a can of wd40 with the hose and spray it allot it should loosen up your shifter. Having lived in the northeast too much salt on the roads really rusts things out.
    MTopp likes this.
  14. Mar 14, 2014 at 4:20 PM
    topper
    topper Member
    Ottawa
    07 Tacoma TRD
    air bag rear suspension, 2.5" suspension lift: Bilstein 5100 shocks front and rear, eibach front spring, extra leaf for the rear
    I have the same problem with my 07 with the addition of it rolling in Park a couple of times because it wasn't IN Park. Is this also part of the problem? Anyone know?
  15. Mar 15, 2014 at 6:11 AM
    #35
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Sounds likely - when it gets stubborn about shifting, it doesn't like to move either way, so it may well not go quite all the way into P. Truthfully, I'd never thought about that aspect before - when mine gets stubborn, I work it fully out (shifting back & forth) until it frees up, every time... so I've never had mine do that.
    It could certainly be a safety issue, if it fails to shift all the way into Park. At this point, since you know about it, the liability now falls to you. To... all of us who own these trucks & have this problem.
  16. Mar 15, 2014 at 8:22 AM
    #36
    topper
    topper Member
    Ottawa
    07 Tacoma TRD
    I think that I will start by replacing the PRNDL switch, but I can't find it. What is the actual name of this part or a part number? Anyone know?
  17. Mar 15, 2014 at 11:21 AM
    #37
    Supramacy
    Supramacy Well-Known Member
    it would be the park neutral switch, which is on the tranny. I've changed a couple of these for related symptoms but I'd also check the shifter cable to be sure it's not starting to seize.
  18. Mar 16, 2014 at 5:04 AM
    #38
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Definitely... do NOT start by replacing ANYTHING - especially anything as expensive as these switches. START by INVESTIGATING. Discover what the problem really is, and deal with the problem. Otherwise, you'll just be throwing money at it in hopes that it'll go away.
  19. Mar 16, 2014 at 4:08 PM
    #39
    topper
    topper Member
    Ottawa
    07 Tacoma TRD
    Thanks guys.
  20. Mar 16, 2014 at 6:27 PM
    #40
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I had this exact problem....Sticky shifter on automatic trans,... intermittent...it would come and go... not a grease or lube issue....Not a clod/warm issue.
    I finally fixed the problem....
    The problem was a rusted and corroded electrical connection on the left side of the auto tranny..... there is a bundle of wires that attach to the rear left on the tranny... the bracket that holds the "male" end was corroded real bad..... I drenched that bugger with brake cleaner then sprayed dilectric grease in both ends and reconnected them....
    Have not had a problem since that fix.....
    Check this out guys.....
    Jon G likes this.
