05+ Tacoma Tail gate reinforcement group buy
Discussion in 'Group Buys' started by RelentlessFab, Dec 17, 2012.
  1. Mar 25, 2015 at 12:13 PM
    #621
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Dude. Let's get it to 110 and have Relentless pay us!
  2. Mar 25, 2015 at 12:14 PM
    #622
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    WHAT? Great idea! :D
  3. Mar 25, 2015 at 12:15 PM
    #623
    VolcomTacoma
    Jeff
    NorCal
    Doubtful, bro, but who knows! I think if you were to straighten out your tailgate and install this, it will probably help keep it straight after that. I would advise the steel one and maybe some sort of strengthened mounting lol
  4. Mar 25, 2015 at 12:42 PM
    #624
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    LOL doesnt quite work that way. :sorry:
    Yeah thats probably the case. Straighten the tailgate as much as possible and cover the damage with the reinforcement. Should hold the load on the damaged gate, but unless the gate is pre-straightened then it A) probably wont fit over the tailgate and B) would pre pre-stressed before load is applied from loading things making the amount the reinforcement helps stiffen the tailgate reduced.
  5. Mar 25, 2015 at 3:41 PM
    #625
    VolcomTacoma
    Jeff
    NorCal
    I think you'd be fine straightening it out as much as you can and if you can fit the reinforcement on it it'll work...but god help you if you ever exceed what that steel can hold. As soon as the steel starts to bow at all, it'll probably start popping screws and the tailgate might collapse again lol. But you'd probably have to have a couple hundred pounds on the tailgate to do that.
  6. Mar 25, 2015 at 4:47 PM
    #626
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    My bad..... Your right 1st of April........
  7. Mar 25, 2015 at 4:49 PM
    #627
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    Bump'd
  8. Mar 26, 2015 at 6:30 AM
    #628
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Any more takers on this GB? Would be great to get 20.
  9. Mar 26, 2015 at 10:17 AM
    #629
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Yikes... I just don't know how to straighten it... I've been on the lookout for a new BSP one. The white ones are a dime a dozen but I don't want to paint. I would think it would probably be a good idea to buy a new one and reinforce it. :/
  10. Mar 26, 2015 at 10:41 AM
    #630
    RelentlessFab
    Eric
    Sparks, NV
    Cut a wood 4x4 the width of the bed to it fits in front of/against the steel upright supports in the rear corners of the truck bed, remove tailgate skin and cap, hook a chain into the cutout in the top edge of the tailgate where it's bent(with the gate up/closed) then use a piece of wood or steel tube as a lever while prying against the 4x4 at the bottom. Should give enough mechanical advantage to pull the tailgate straight or close to it. :cool:
  11. Mar 26, 2015 at 2:03 PM
    #631
    dakotasyota
    Dakota
    Ellensburg, WA
    Hmmmm... I like. :cool:
  12. Mar 27, 2015 at 6:27 AM
    #632
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Anyone who has installed this use the two strips of foam tape similar to what KB Voodoo supplies with his tailgate cap? Or is that too much?
  13. Mar 27, 2015 at 6:41 AM
    #633
    RelentlessFab
    Eric
    Sparks, NV
    Yes I've used 1/8" "camper tape" before. Not 100% necessary but recommended.
  14. Mar 27, 2015 at 12:58 PM
    #634
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    1. Rmorse PC diamond plate alum
    2. bigcrab raw 14G steel ( if thats allowed)
    3. VolcomTacoma2011 Powdercoated Steel
    4. adanfon bare steel
    5. scott96929 steel pc
    6. Negative1 - Powder coated steel
    7. crux - Plate alum (Plan to skin with bamboo wood as a cutting / cooking surface)
    8. 96FIDO96
    9. NotRed - PC steel
    10. Azdesert50 bare Alum
    11. TheNatural - bare steel
    12. Tacomanamedolga - powdercoated steel
    13. SteelHorse - Black Powder Coat Black, plate alum
    14. Machvii- Black powdercoat, Aluminum
    15. glwood6 - Black powdercoat aluminum
    16. mynameistory - Black powdercoat, aluminum.
    I'm in.
  15. Mar 27, 2015 at 3:06 PM
    #635
    VolcomTacoma
    Jeff
    NorCal
    Woohoo almost to 20%!
  16. Mar 27, 2015 at 4:44 PM
    #636
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    5100/887, Dakars, 285s, Built Right UCAs, Icon rears
    I'm in for an aluminum PC one.
    8. 96FIDO96
    17. rileySB- Black powder coat, aluminum
  17. Mar 27, 2015 at 7:45 PM
    #637
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    Wondering if this will raise the tailgate cap any higher than stock?
    I ask cause I have a Diamondback tonneau cover and it needs maybe a 1/4" higher to contact the weather striping for the rear to seal better. I'm interested in this also cause I'm a big guy so I'm worried if I sit in back it will bend.
  18. Mar 27, 2015 at 7:56 PM
    #638
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    Hope we get 20 buyers. I'm changing my order from Steel powder coat to Aluminum powder coat..........
  19. Mar 27, 2015 at 8:12 PM
    #639
    VolcomTacoma
    Jeff
    NorCal
    This will totally work well for you
  20. Mar 28, 2015 at 4:49 AM
    #640
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    8. 96FIDO96
    18. imom - Black powder coat, aluminum
    2 more to go
