05+ Tacoma Tail gate reinforcement group buy
Discussion in 'Group Buys' started by RelentlessFab, Dec 17, 2012.
  1. Mar 28, 2015 at 7:40 AM
    #641
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Especially if you get diamond plate; it will match your cover.
  2. Mar 28, 2015 at 3:03 PM
    #642
    UoD
    UoD Well-Known Member
    Charleston, SC
    2015 Tacoma TRD Sport DCSB 4x4
    N-Fab 3" Main Tube Textured Nerf Bars (T0580CC-TX), Toyota OEM Bed Extender, Swapped Entune Plus for Entune w/ Nav, Undercover SE Tonneau, TRD Pro wheels, Falken Wildpeak AT3W's (265/70/17)
    So --- I'm thinking about joining in on this. Question : Any good reason to get the aluminum over the steel? I would assume the steel would hold up better. Pardon my noobish-ness here ... just want to make sure I am not missing something.
    Also --- how well does the powder coat hold up? Would I be better off just getting bare and spraying it with Rustoleum bed liner?
  3. Mar 28, 2015 at 3:05 PM
    #643
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I went with aluminum so it wouldn't rust like steel would. Even with powdercoat it may get chipped when loading stuff depending on how you use your truck.
    The aluminum is softer, but definitely holds up better than the plastic and it wont rust, so touch ups don't have to happen as often
  4. Mar 28, 2015 at 4:15 PM
    #644
    ThomasMore66
    Dallas/Fort Worth & Durango
    I just used one and I stuck it to the tailgate protector and not to the paint. Cap is too close in the middle for there to be a piece of foam.
  5. Mar 28, 2015 at 4:41 PM
    #645
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Gotcha, thanks!
  6. Mar 29, 2015 at 2:02 PM
    #646
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bump for 2 more to make 20.
  7. Mar 29, 2015 at 3:50 PM
    #647
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    So I took Swordknives photo to help ask my question. I see on relentless' website that you need to "Required tools are a torx bit for the screws, and a rubber mallet or block of wood to curve cover to tail gate shape if desired."
    So how does one bend this aluminum piece? I have to start make a jig piece of wood to put in the channel of the tailgate cover and try to shape it so the gap follow the curve of the tailgate? Has anyone tried this...doesn't seem very easy. I think if I tried this...the bend lines will not be uniform at all after trying to shape the curve with a mallet.
    Too bad RelentlessTaco couldn't make his jig to incorporate this bend into his jig when he uses the CNC brake to form the tailgate. Is it possible RelentlessTaco to do this? I'm just curious.
  8. Mar 29, 2015 at 4:53 PM
    #648
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    That's not something we will be doing. It's only noted because some people don't understand the tailgate curves so the reinforcement has a bit of gap at the edge. Not something I see worth messing with. It's not bad. Some customers just expect a perfect fit like a molded plastic cap. This just might not be for those who are that anal about a slight gap.
  9. Mar 30, 2015 at 12:25 AM
    #649
    imom
    CAL
    2014 Regular Cab
    I am anal...but I see the practical benefit of your product...was just wondering if it was possible since your note suggested you can do it...thanks for letting me know it's not available.I can live with it. Out of curiousity...would it be difficult to have a shorter lip to it so it doesn't accentuate the gap, so say if the lip is 2 inches...to make the lip 1 in or 1 1/2 in instead.
    Or have a minimal lip altogether so the factory plastic cap can be installed over it. I just like factory look.
    Really cool that you made this product and looking forward to it.
  10. Mar 30, 2015 at 6:37 AM
    #650
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I am pretty picky as well but to be honest it looks much worse in the pictures than it does on the truck. Most of the time when you are looking at your truck the tailgate will be up and it's hardly noticeable at all. From someone that has had this on their truck for some time now I can tell you the benefits far outweigh that little cosmetic flaw. If you are putting things in your bed of your truck you do not need to worry about bending your tailgate. It's a great piece of mind.
  11. Mar 30, 2015 at 6:48 AM
    #651
    ThomasMore66
    X2.
    Also, I have one of those spider web tie-down systems and the little lip comes in handy when you need a place to hook an anchor. It's a good investment.
  12. Mar 30, 2015 at 3:13 PM
    #652
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Bump'd, for the list
    If you're in, copy and paste your name on the list.
    1. Rmorse PC diamond plate alum
    2. bigcrab raw 14G steel ( if thats allowed)
    3. VolcomTacoma2011 Powdercoated Steel
    4. adanfon bare steel
    5. scott96929 steel pc
    6. Negative1 - Powder coated steel
    7. crux - Plate alum (Plan to skin with bamboo wood as a cutting / cooking surface)
    8. 96FIDO96
    9. NotRed - PC steel
    10. Azdesert50 bare Alum
    11. TheNatural - bare steel
    12. Tacomanamedolga - powdercoated steel
    13. SteelHorse - Black Powder Coat Black, plate alum
    14. Machvii- Black powdercoat, Aluminum
    15. glwood6 - Black powdercoat aluminum
    16. mynameistory - Black powdercoat, aluminum.
    17. rileySB- Black powder coat, aluminum
    18. imom - Black powder coat, aluminum
    2 more, lets get it done!!!
  13. Mar 31, 2015 at 4:57 AM
    #653
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Btt for 2 more.
  14. Mar 31, 2015 at 6:38 AM
    #654
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Come on guys! Pretty cheap way to ensure you don't fold your tailgate in half!
  15. Mar 31, 2015 at 11:09 AM
    #655
    imom
    CAL
    2014 Regular Cab
    My apologies... I decide a different route. Great deal.
    8. 96FIDO96
    18. ryanjboutin - bare aluminum
  16. Mar 31, 2015 at 11:21 PM
    #656
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Pricing info is on P31
    8. 96FIDO96
    19. Naveronski - Black Powdercoat, Aluminum
  17. Apr 1, 2015 at 5:53 AM
    #657
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Woo Hoo! And I make 20! The previous 19 of you should give me a 1% kick back ;)
    8. 96FIDO96
    20. DVexile - Black Powdercoat, Aluminum
  18. Apr 1, 2015 at 6:03 AM
    #658
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    8. 96FIDO96
    Fabricating my own this week.
  19. Apr 1, 2015 at 7:21 AM
    #659
    ThomasMore66
    And then there were 19...
    Bamboo?
  20. Apr 1, 2015 at 7:35 AM
    #660
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    7. coop68- bare alum
    8. 96FIDO96
    20. DVexile - Black Powdercoat, aluminum
    I take lucky number 7 back at 20.
