05+ Tacoma Tail gate reinforcement group buy
Discussion in 'Group Buys' started by RelentlessFab, Dec 17, 2012.
  1. Oct 1, 2015 at 1:46 PM
    #801
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Pro tip: buy locally. Shipping is more than the hardware.
    @scocar
    MQQSE likes this.
  2. Oct 1, 2015 at 2:10 PM
    #802
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I bought the part number a couple pages back locally for about 1.70 each. And they got them next day. So +1 for getting them locally
  3. Oct 1, 2015 at 2:10 PM
    #803
    scocar
    scocar hypotenoper
    Thanks. Yeah, I just wanted to see what they looked like. I would defintitely just run up to Maita.
    OK, so these are the same as the ones at the bottom of the gate? Damn. I got all excited and thought someone had already come up with the solution I want.
    I'm really interested in the countersinking the aluminum idea for a flush, flat gate. Not even sure there is enough thickness to countersink, and those coarse threads into plastic...meh, going to be hard to find something of the right spec that would work. Tired of this plasticky cheap shit. Hmmm, maybe rivnuts.
    I ahve yet to find 5 minutes to even remove mine and stare at it for a while. Fuck. But this mod is next on the list without a doubt, just to get my Leer door to close/seal better. Curved tailgate FTMFL.
  4. Oct 1, 2015 at 3:28 PM
    #804
    T4RFTMFW
    I don't think anyone has countersunk yet. It's pretty thin..
  5. Oct 1, 2015 at 5:07 PM
    #805
    scocar
    scocar hypotenoper
    Yeah. .10 inch I think, so that'd like, fuck, I forget, 3/32ish?
  6. Oct 1, 2015 at 5:07 PM
    #806
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    As other people already said, these screws are pan head just like the ones on the bottom of the the tailgate. Looks like you figured that out once you had a good link to see the screws. This is still an improvement over the normal top screws which have shoulder making them stick up even more.
    I agree the aluminum is probably far too thin for counter sinking given the screw diameter. You could probably have a thicker Al plate made that would sit on top of this thinner tailgate reinforcement. The Relentless material needs to be reasonably thin since it is bent to form a cover and lip for the top of the tailgate. But you could easily take something like a 3/16 Al plate that is just flat and put counter sunk holes in it. You could put that on top of the Relentless cover like some people put the old plastic cover on top of the Relentless cover.
  7. Oct 1, 2015 at 5:11 PM
    #807
    T4RFTMFW
    Or, another option to consider is to not be an anal retentive bitch. :D
  8. Oct 1, 2015 at 5:13 PM
    #808
    scocar
    scocar hypotenoper
    Yeah, I will likely end up doing the latter in the short term at least. The whole tailgate is such a weird design.
  9. Oct 1, 2015 at 5:17 PM
    #809
    scocar
    scocar hypotenoper
  10. Oct 1, 2015 at 5:25 PM
    #810
    T4RFTMFW
  11. Oct 2, 2015 at 6:32 AM
    #811
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    @scocar are you going to put the factory cover back on over the Relentless skin?
    Like this
  12. Oct 2, 2015 at 8:19 AM
    #812
    scocar
    scocar hypotenoper
    I didn't intend to, but it may be necessary to avoid having the screw heads interfere with loading /unloading material and accidentally damaging it (like bags of concrete or lumber or furniture). I suppose it will make it easier to slide stuff in and out anyway since it will keep a relatively level plane between the top lip of the tailgate and the bottom of the bed. I'm probably just being too fussy as James opined.
  13. Oct 2, 2015 at 8:51 AM
    #813
    mach1man001
    Rob
    Blackstone, MA
    That's not my pic but that's the way I have mine too. I think it protects the RF plate from scratching all up (except the top), plus it keeps the factory look. Just do that and use the other bolts and you are good to go.
  14. Oct 2, 2015 at 8:57 AM
    #814
    T4RFTMFW
    If you keep the OEM cover you don't need new bolts.
    In fact, Scott - I have 7 of the bolts you need if you are just going to run the Relentless piece and not return the OEM tailgate skin if you want them.
    Fair warning: they're in my garage.. I am sure I can find 6 in 10 seconds but the 7th may be tricky.
  15. Oct 2, 2015 at 10:28 AM
    #815
    mach1man001
    Rob
    Blackstone, MA
    Really? I needed them. Whats different now?
  16. Oct 25, 2015 at 1:42 PM
    #816
    scocar
    scocar hypotenoper
    Well...I am running into this on my 2015. I already pulled the tailgate off the truck because it seemed like I could not even get your plate on the gate without marring the exterior bulge of the OEM gate without sliding your reinforcement on from the side. I've even trimmed the flash off the plastic screw retainers in the OEM gate to minimize interference. Some were sticking up as much as 1/8 - 1/4 proud. I was eyeballing the two panhead torx head screws at the top of either end thinking those are coming off next...
  17. Nov 23, 2015 at 2:06 PM
    #817
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I have the cap (narrow top piece) I'll sell. Where are you?
