05+ Tacoma Tail gate reinforcement group buy
Discussion in 'Group Buys' started by RelentlessFab, Dec 17, 2012.
  1. Mar 6, 2013 at 10:45 AM
    #81
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Eric,
    After talking to my metal working friend I have swapped to aluminum for my tailgate reinforcement, I changed it on the list here.
  2. Mar 6, 2013 at 11:59 AM
    #82
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Why, what did your friend say? Please share.
  3. Mar 6, 2013 at 9:59 PM
    #83
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    He works with sheetmetal most of he time in our machine shop and is a wizzard with bend allowance and such stuff, and can weld thin aluminum like mad.
    Anyway he said he would prefer the 0.100" aluminum because while it might be a bit weaker (MAYBEE, like Eric said..), but the advantages are it does not need to be painted, and a bit lighter than the 14G steel.
    That said, if you regularly drag heavy stuff across your tailgate which has bolts or nails sticking out, the aluminum (being softer) will gouge whereas the steel will just scrape off the paint (but will then rust).
    So both materials have benefits, and actually I would rock either one. In the end I think aluminum will be less care in the long run as you can touch up the paint when you feel like it as it is not going to rust, and you never need to worry about the inside face.
  4. Mar 7, 2013 at 7:35 AM
    #84
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Okay, I did the math of comparing the weight of the 0.100" Aluminum to the 14G Steel. These are the materials we can choose from for this Group Buy.
    6061 Aluminum (other alloys are very close in weight) = 1.41 lbs./square foot,
    14G hot rolled Steel = 3.13 lbs/square foot
    I estimate 8 square feet of material so we are talkng 25 pounds for the steel reinforcement plate or 11.3 pounds for the aluminum reinforcement plate.
    If weight at the extreme rear of the truck is important to you - You now have this data.
  5. Mar 7, 2013 at 8:41 AM
    #85
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    You're actually very close! I've found 24lbs steel, and 13lbs aluminum when I weighed them for shipping purposes.
    I think that may have been a diamondplate aluminum cover, so the tread pattern added a bit of weight I guess.
  6. Mar 7, 2013 at 8:59 AM
    #86
    Swordknives
    Swordknives mmm Tacos
    South OC CA
    2013 Dbl cab LB v6 SR5
    BTW if you are worried about scrapping paint off when loading you can reuse the plastic on your tailgate. That way you only have the bent lip that goes over the top of your tailgate exposed.
    I wanted to get the stock look. so this was the way I went. I do have photos earlier in this thread.
    Also the weight when opening and closing the tailgate is not a big deal. it feels like an old steel truck tailgate "sturdy" is what my dad called it.
  7. Mar 7, 2013 at 10:43 AM
    #87
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Swordknives, love that little "bouncy" girl in your signature line!
  8. Mar 7, 2013 at 11:28 AM
    #88
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    I read the install description on your website, does it really require pounding to make the metal shape over the tailgate? Why not make it flush and re-use plastic cover?
  9. Mar 7, 2013 at 12:12 PM
    #89
    RelentlessFab
    Eric
    Sparks, NV
    That is entirely up to the buyer, it is not necessary if the gaps at the edge of the tailgate between the cover are acceptable to them. You can see in swordknives pics posted the curvature of the tailgate and how the cover sits close to the tailgate in the center, and then gap increases near the ends of the tailgate.
    The main plastic cover of the tail gate can be re-installed if desired, however the one that clips onto the top of the tailgate cannot be reinstalled
  10. Mar 7, 2013 at 1:30 PM
    #90
    2ski4life7
    Seattle WA
    I see. When will this group buy end?
  11. Mar 7, 2013 at 1:52 PM
    #91
    RelentlessFab
    Eric
    Sparks, NV
    I'm thinking we'll end it Friday next week, then order material Monday, cut, bend ship. Should all be shipped by the end of the month that way.
  12. Mar 7, 2013 at 5:11 PM
    #92
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  13. Mar 8, 2013 at 7:52 AM
    #93
    Swordknives
    South OC CA
    The gap is small and not very noticeable if you are in a hurry like me to get it on. However I was debating doing the bending now, it only takes a few min to unscrew the bolts on and off.
    Desert Drifter
    I totally stole it from the funny GIF thread.. I liked it too. good thing my wife does not know, she would not approve.
  14. Mar 8, 2013 at 9:32 PM
    #94
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Rats, this doesn't look to be compatible with my Roll'n'Lock tailgate/tonneau.
  15. Mar 10, 2013 at 7:06 AM
    #95
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Did not see it mentioned. What alloy of aluminum and heat treat if any ae you using for the aluminum. 6061, 6061T6, or 5052?
    Is diamond plate 6061T6 a choice in the style shown on your webpage?
    Thanks
    PK
  16. Mar 10, 2013 at 8:07 AM
    #96
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    The aluminum is 5052. I asked Eric in a pm a while ago. hpe that helps
  17. Mar 11, 2013 at 6:59 PM
    #97
    tomwopat
    tomwopat Well-Known Member
    Memphis, TN
    2012 DCSB Prerunner
  18. Mar 12, 2013 at 9:51 AM
    #98
    RelentlessFab
    Eric
    Sparks, NV
    I think we'll call this a 20% discount with the number we're at, hows that sound everyone?
    I can start sending out PMs with the discount code if some of you would like to begin the order process.
    I've currently got enough material for 7 aluminum covers, and a couple steel covers but steel is easy to pick up in town.
  19. Mar 12, 2013 at 11:25 AM
    #99
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Sounds good to me Eric. PM me and I will submit payment or however you ar working this. let's see $169 less 20% comes to about $125.20 plus shipping....
  20. Mar 12, 2013 at 1:58 PM
    #100
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    Yeah, same here. Looking forward to this. Send the code and I'll get the order/payment in. Thanks
