05 tacoma transmission fix quetion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmacky, Jan 23, 2025.
  1. Jan 23, 2025 at 11:25 AM
    Cmacky
    Cmacky [OP] Member
    stock 05 full cab tacoma
    Hi all, this is the corroded bolt terminal for my transmission power!! I have a few questions and am in need of some advice. 1: how do I go about removing this crimp? if that's not an option how do I go about cutting, stripping, and attaching new wire? Also what gauge is this wire and which is positive and negative? 2: WHAT IS THIS PART CALLED!!! Thats probably my most important question haha. all advice is welcome and for any advice on fixing please mention any special tools I'll need. Thanks for any help getting my baby running again!!
  2. Jan 23, 2025 at 3:12 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. I don't know specifically what the OEM part number or name is for that terminal, but essentially it is a large gauge cable lug and appears to be going to the alternator not the transmission. OEM wire I believe is 2 gauge, you can likely find a crimp lug available at your local auto parts store. Good luck on that cable (and all that rust, yikes).
    Edit: Thread linked below has some photos that might help in your process of doing the repairs.
    https://www.tacomaworld.com/threads...-2nd-gen-tacoma-writeup-with-pictures.664674/
    Cmacky[OP], sparkystaco and TnShooter like this.
  3. Jan 23, 2025 at 3:14 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Take it to a mechanic you clearly don’t have a clue. No offence.
    TegoTaco likes this.
  4. Jan 23, 2025 at 3:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'd start by unbolting the wire from the alternator.
    Then mix up some baking soda in a hot water.
    Dip the wire into the water/soda. Let it soak for about 1 min.
    Scrub the crimp and eyelet of the wire with a brush.
    Rinse the wire, eyelet, and crimp well with clean water.
    Dry it the best you can. Then take a good beefy pair of pliers and squeeze the crimp tight.
    Next, brush the mounting location on the alternator.
    That way everything is clean when when you bolt it back up.
    FWIW, can you tell use what transmission issues you are having?
  5. Jan 26, 2025 at 1:29 PM
    Cmacky
    Cmacky [OP] Member
    I fixed it. it wasn't hard. We all gotta start somewhere, thanks for the useless advice.
    007fodo likes this.
  6. Jan 26, 2025 at 1:32 PM
    Cmacky
    Cmacky [OP] Member
    thanks, I ended up realizing I could use a generic bolt terminal, went to AutoZone, and picked up one for a few bucks with some shrink wrap. She's running like a dream.
    ABA180 and wi_taco[QUOTED] like this.
  7. Jan 26, 2025 at 1:33 PM
    Cmacky
    Cmacky [OP] Member
    got it running again ended up just cutting the wire and crimping a new terminal on!
    TnShooter[QUOTED] likes this.
  8. Jan 26, 2025 at 1:38 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Good to know there's enough length to cut off the coroded end and crimp onto fresh copper :thumbsup:
  9. Jan 26, 2025 at 1:45 PM
    Cmacky
    Cmacky [OP] Member
    There is but lets just say you get 1 try haha.
    007fodo[QUOTED] and TnShooter like this.
