'05 Tacoma Variable Displacement (VD) AC-Yes or No?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjr23, Aug 4, 2022.
  1. Aug 4, 2022 at 8:29 AM
    bjr23
    bjr23 [OP] Member
    '05 Tacoma crew cab
    none
    I've "Googled" to no avail. I just need to know if the Second Gen '05 has that "VD"? This unit has the electric clutch. It has refrigerant pressure (charge). We bypassed the relay and the clutch energized and still no pumping action. From what I've read generically if the vehicle has the "VD" then it may not pump till the computer tells it to? Would like to know if this truck came with the VD or not? Thank you in advance. bjr23
  2. Aug 4, 2022 at 8:46 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No 2nd gen Tacoma's don't have variable displacement compressors, if the clutch is turning and it's not pumping then the compressor is junk.
    If the compressor has indeed grenaded and there is metal contamination in the system you must replace the condenser, expansion valve and screen, and flush all the lines and evaporator thoroughly or you will have repeat failure.
    In some cases the metal gets into the evaporator and it needs to be replaced too but that doesn't happen too often.
    TnShooter likes this.
  3. Aug 4, 2022 at 10:36 AM
    bjr23
    bjr23 [OP] Member
    '05 Tacoma crew cab
    none
    can the expansion valve be accessed thru the firewall? Also Where is the Low side switch Located? All I've found is the High side switch.
  4. Aug 4, 2022 at 10:38 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Dm93 likes this.
