'05 Tacoma won't shift into 4WD in cold weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MarkCNP, Nov 27, 2011.
  1. Nov 27, 2011 at 10:36 PM
    MarkCNP
    MarkCNP [OP] Active Member
    Mark
    Alberta
    '09 DCLB Sport 4x4
    OME 885 Dakars LR UCA Nitrocharger Sports
    In weather below freezing my truck won't shift into (or out of) 4WD. Anyone seen this before or have any ideas? I had this problem last winter and the problem has come back since the weather has become colder.
    Thanks in advance.
  2. Nov 28, 2011 at 9:42 AM
    MarkCNP
    Mark
    Alberta
    '09 DCLB Sport 4x4
    Thanks for the suggestion! Where are those actuators located?
  3. Nov 28, 2011 at 9:54 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    Mine ended up being a bad ground connection on the front diff sensor.
    Found out because replacing to a new sensor didn't fix it.
    If you download the service manual, it shows you how to check and troubleshoot the 4x4 engagement.
  4. Nov 28, 2011 at 10:14 AM
    MarkCNP
    Mark
    Alberta
    '09 DCLB Sport 4x4
    I`ve searched through the online manual and couldn`t find anything on 4wd troubleshooting - what should I be searching for
  5. Nov 30, 2011 at 10:06 AM
    buck
    Ontario, Canada
    Look for the Transfer (case) section. It's listed as section VF2BM. It's all there, starting at page TF-1.
  6. Nov 30, 2011 at 11:13 AM
    MarkCNP
    Mark
    Alberta
    '09 DCLB Sport 4x4
    Thanks for the input, it is much appreciated!
