05 tensioner pulley replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Badass05, Aug 11, 2024.
  1. Aug 11, 2024 at 2:42 PM
    Badass05
    Badass05 [OP] New Member
    2005 tacoma
    none
    I am trying to remove the bolt that holds the pulley for the tensioner, i tried both ccw and cw with no movement. I am afraid i will snap it off. i was going to replace the whole thing, but the bottom bolt for the a/c the head stripped off so now i just need to replace the pulley itself. i tried taking the new on off going ccw but it ended up snapping off.
  2. Aug 11, 2024 at 5:21 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I believe that one is a reverse thread?
    TnShooter likes this.
  3. Aug 11, 2024 at 7:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it’s the 4.0 engine.
    You are correct.
    It is left hand thread.
    So, you need to “tighten it”. To take it off.
    winkel[QUOTED] and Jimmyh like this.
  4. Aug 11, 2024 at 7:12 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  5. Aug 12, 2024 at 12:36 PM
    Badass05
    2005 tacoma
    none
    Thank you !!!!
