05 toyota tacoma wont stay running.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotabecka, Mar 26, 2018.
  1. Mar 26, 2018 at 9:57 AM
    Toyotabecka
    Toyotabecka [OP] Member
    Rebecca
    05 toyota tacoma
    4.0 auto
    Hi there I have recently posted on thread but wanted to follow up an try again. I have a 05 toyota Tacoma 4.0, about 3 weeks ago, my truck seemed like it was lunging me an almost didn't make it home. I went though threads an tried to troubleshoot it myself. Here is what all I have done.
    Mass air flow sensor (New)
    Air filter(new)
    Spark plugs (new)
    Downstream left 02 (new)
    Pcv valve (new)
    Sea foam fuel system( then replaced fuel pump system)
    Sprayed brake cleaner on all vacume hoses and around manifold to see if idle returned to normal, (didn't help)
    It would run then rough idle, press the gas an would stay running. Took it to get diagnostics test an Would not stay running long enough to test any one thing in particular.
    Did not through any codes..
    Now when you start it, it will run for a second an die
  2. Mar 26, 2018 at 10:01 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Maybe a vacuum leak
  3. Mar 26, 2018 at 10:03 AM
    YoterHead
    YoterHead Well-Known Member
    Fuel pump?
  4. Mar 26, 2018 at 10:11 AM
    Leifmealone
    Leifmealone Well-Known Member
    San Diego/Northern California
    2005 Tacoma 4cyl 4x4
    Have you disconected the battery recently?
  5. Mar 26, 2018 at 10:31 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Yeah...disconnected the battery
  6. Mar 26, 2018 at 10:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How are the battery connections? How old is the battery?
  7. Mar 26, 2018 at 10:31 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Changed the fuel pump
    Torspd likes this.
  8. Mar 26, 2018 at 10:32 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Almost new battery.
    Torspd likes this.
  9. Mar 26, 2018 at 10:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have a scangauge 2, Ultragauge, or know someone close enough that has one to check your engine voltage? A voltmeter perhaps?
  10. Mar 26, 2018 at 10:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When you said it would run with the foot on the pedal, at higher rpm than idle, how did it sound? Normal, or rough running?
  11. Mar 26, 2018 at 10:34 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    2ND took it to a snap on guy to try to test/read codes.
    NO codes an wouldn't stay running to test things out?
  12. Mar 26, 2018 at 10:35 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Rough, that's when we checked the vacume hoses
  13. Mar 26, 2018 at 10:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Continually rough then. May be a coil pack issue. May be the alternator. May be neither.
    If you can check the voltage while running, that would be very helpful.
    Also, while you have the engine running, try to keep the revs to ~1000 (since it dies with your foot off), unplug the wires from each coil pack one at a time. Wait long enough to see if the engine operation gets rougher, or stays the same.
    If the operation gets worse, that coil pack is working properly. If it doesn't change, then that coil pack is a possible culprit.
    REDdawn6, BassAckwards and PzTank like this.
  14. Mar 26, 2018 at 10:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What all electrical mods does your truck have?
  15. Mar 26, 2018 at 10:44 AM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    possible TPS is bad?
  16. Mar 26, 2018 at 10:48 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Stock truck. No changes. Can't keep it running to check coil. Tried to put the foot on the pedal, but dies. We are taking it to the dealership tomorrow. Just wanted to try an save some $$$. Simple 150 just to have them try to diagnose it.
  17. Mar 26, 2018 at 10:49 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Anyway I can test the tps?
  18. Mar 26, 2018 at 10:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Keep us posted. Very curious what you find.
  19. Mar 26, 2018 at 10:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes. Remove the intake from the throttle body. Turn the key to the ON position. Have some one watch the throttle valve while another pushes the pedal. See if it moves.
    aeok18109 likes this.
  20. Mar 26, 2018 at 11:15 AM
    Leifmealone
    When i disconnected my battery my truck did the same thing. Ran rough and acted super funny. Im pretty sure if you disconnect it it messes with the memory of the computer and has to relearn by going through a drive cycle? I Could be wrong
