05 toyota tacoma wont stay running.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotabecka, Mar 26, 2018.
  1. Mar 26, 2018 at 11:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is a problem. Full pedal travel down should make full throttle valve open.
  2. Mar 26, 2018 at 11:21 AM
    Toyotabecka
    Toyotabecka [OP] Member
    Rebecca
    05 toyota tacoma
    4.0 auto
    What did you do to fix that?
  3. Mar 26, 2018 at 11:22 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Didn't hold the pedal down. That was just turning over the key.
  4. Mar 26, 2018 at 11:22 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  5. Mar 26, 2018 at 11:23 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
  6. Mar 26, 2018 at 11:29 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Okay did the throttle test tight this time. I does open all the way
  7. Mar 26, 2018 at 11:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The pedal is easy to remove and inspect internally.
  8. Mar 26, 2018 at 11:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Then disregard my last post. Good. So it leaves it to an engine operational problem.
  9. Mar 26, 2018 at 11:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You need to test the voltage.
    devkurf likes this.
  10. Mar 26, 2018 at 12:16 PM
    YoterHead
    YoterHead Well-Known Member
    Maybe the fuel pump relay needs swapped out?
  11. Mar 26, 2018 at 3:30 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I see a lot of comments about engines dying or running roughly after having battery ground strap off. I changed spark plugs on mine a few weeks ago. Had the ground strap off. Truck fired right up and ran smooth as glass after reconnecting ground strap. Cable was off a couple of hours, at least. Total time cable is off battery may be an issue.
  12. Mar 27, 2018 at 6:58 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Could my problem be the ecm needs to relearn? Where i diconnect the battery? Any ideas on how to reset it?
  13. Mar 27, 2018 at 7:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Leaving the battery disconnected for enough time to have the capacitors bleed down, will reset it. 10-15 minutes is more than enough time.
  14. Mar 27, 2018 at 7:36 AM
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Anyhting I gotta do eith pressing the glass pedal down?
  15. Mar 27, 2018 at 8:27 AM
    #35
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Several people have said to check the system voltage, overcharging can cause the issue you are having as well as excessive A/C voltage from the alternator.
    EZ to check, disconnect the alternator and see if the truck stays running. IF so, you've found your problem.
    To verify, put your DVOM on A/C volts and check between the battery terminals with the engine running and alternator hooked up. You should have Less than .2 volts, ZERO volts is ideal.
    IF that's the issue, I'll only charge you half of the 150 bucks the dealership monkeys are charging you :bananadance::bananadance::bananadance:
    Torspd likes this.
  16. Apr 2, 2018 at 3:17 PM
    #36
    Toyotabecka
    Rebecca
    05 toyota tacoma
    4.0 auto
    Just picked my truck up from the dealer. Misfire in cylinder one.. says due to aftermarket spark plugs, bad ground. Gonna drive it to work tomorrow an see how it goes.
  17. Apr 2, 2018 at 7:29 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which spark plugs did it have in there?
