05 tranny oil change
Discussion in '4 Cylinder' started by hondarida122, Dec 21, 2008.
  1. Dec 21, 2008 at 2:23 PM
    hondarida122
    hondarida122 [OP] Active Member
    Falmouth,MA
    08 tacoma
    I'm goin to assist my friend in doing a oil change. He has 120,000 miles on that same tranny fluid. It's a 5 speed manual. I'm just looking for a some help if you have a tutorial post it up. What oil should he use? Thanks
  2. Dec 21, 2008 at 2:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Easy to do. First remove the fill plug, then the drain plug (you do it this way just incase you cant get the fill plug off, you know to stop right there). Drain the oil out, put in drain plug, and fill with your favorite oil. I used Mobil 1 75-90 in my 2000 5 speed, and it shifted much better.
  3. Dec 21, 2008 at 4:20 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    That's smart.
  4. Dec 21, 2008 at 5:35 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    They are changing it on an 05. Don't you mean he needs to use the WS transmission fluid?
  5. Dec 21, 2008 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not on the 5 speed manual.
  6. Dec 21, 2008 at 5:43 PM
    genxer36
    Sean
    Bethlehem,GA
    Well I learn something every day. Thanks
